Installed S50 injectors
    • 34839
    #31
    Originally posted by demlotcrew
    All the M20 boys did this about two years ago and when the cars went on the rollers they were far too rich! Just like the M30 afm its a waste of time.
    A
    I think he's implying that you should have your car tuned for the new injectors..
    • parkerbink
      • Jun 2004
      • 10138
      #32
      Anyone have info on what this will do to emissions? I really need to know before I put the ones I bought in.
      Thanks
      • Mystikal
        Wheel Fitment Expert
        • 9602
        #33
        A
        You need software changes, you don't throw air/fuel mods at an engine (especially such an old ECU system) in the hopes it will magically tune itself.
        • Digitalwave
          is a poseur
          • 6299
          #34
          A
          You mean you "shouldn't," because most people here do.
          RISING EDGE
          • nickmp0wer
            • 1427
            #35
            but isnt it supposed to "learn" changes? Im about to install a Markd chip and 19lb injectors (they were $25 shipped) in my 318. I have been getting just over 30mpg so i will see if it changes, although im sure it will change a little becasue of the new chip and fact i havent driven it in weeks. (i will be flogging it)
            • Digitalwave
              is a poseur
              • 6299
              #36
              Why would you need 19# injectors on a 318?
              RISING EDGE
              • nickmp0wer
                • 1427
                #37
                well i origionally got them for my ITB setup but i think thats going to have to wait till next summer. Now if anything they will jsut be a replacement for my old ones
                • parkerbink
                  • Jun 2004
                  • 10138
                  #38
                  Thanks
                  Can anyone tell me if I should wait to put these and my MarkD 91 octane chip in until after I smog the car ???
                  PLEASE??
                  • nickmp0wer
                    • 1427
                    #39
                    you shouldnt need to
                    • Budget Beater
                      • Aug 2005
                      • 230
                      #40
                      technically you will run rich compared to stock conditions but if you have high flow intake and exhaust then your car will be running leaner than it normally would in which case injectors would help. im sure the better desing of hte injectors also helps driveability as mentioned. You won't get max potential out of injectors without software upgrade but you can still run them without it. running too close to an injectors maximum threshold is not a good idea (on the stock 14.5 ones) so 17lb upgrade is definitely a good upgrade for saftey margin sake. But 19lb injectors seem like pure overkill to me, you would never need that much fuel even with cams on a 2.5L.
                      Also if you get the larger injectors you could always get an adjustable fuel pressure regulator and if you are running too rich you could simply just drop the fuel pressure a few PSI to fine tune and get just the right mixture. that plus a regular aftermarket chip should definitely take care of the tuning problem. custom chip is the best option but it would cost alot more.
                      • Mystikal
                        • 9602
                        #41
                        Motronic 1.3 barely "learns" it's own name. It's really not doing any adapting, contrary to what R3V thinks.
                        Don't throw injectors at an otherwise fine engine unless you know if it is running lean. Bottom line: People, stop guessing what your car needs and actually test it.
                        • nickmp0wer
                          • 1427
                          #42
                          i guess i will just see if my fuel mileage changes
                          • nickmp0wer
                            • 1427
                            #43
