fuel pump / electrical problem
  • NC325iC
    • Mar 2004
    • 6565
    well now we know
    and knowing is half the battle!
    but they never told us what the other half was...
    • komarkjevin
      • Dec 2010
      • 4
      I am pretty sure the fuel pump does not start at all until you turn the key at the beginning, so the relay must be dead, until you turn the key to begin. Another thing you can try is to go through the procedure to remove the anti-theft system, because I believe that to remove the fuel pump.
      r4i
      • Bothfeetin
        • Dec 2010
        • 340
        yea but that would take forever and the i still cant find the problem its driving me insane
        #Treadlifematters
          The fuel pump on an E30 only runs when the DME sees timing data from a rotating engine. What hasn't been established is whether the fuel pump relay is engaging when the engine cranks. Nor has it been established as to whether the fuel pump and FPR are working properly. That requires checking the fuel rail pressure and delivery volume (see the Bentely manual).
          Start there.
          • Bothfeetin
            • Dec 2010
            • 340
            i check the pump its fine... there has to be a wire cut or loose or something somewhere i just cant find it can anyone help!
            #Treadlifematters
            • Ceeker
              • Sep 2009
              • 2821
              check the connections near the pump; take the rear seat out and on the passenger side there is an inspection plate. remove the screws and you have access to the top of the pump. check all wiring for any cracks, fraying etc.
              have someone wiggle the wires to see if the car does anything with ign on.
