Central locking crapper the bed in a big way...
  • nrubenstein
    • 3148
    Sadly, the 330is has no functional locks at the moment and I'll be parking it until that can be taken care of.
    Symptoms:
    Driver's door lock cylinder turns but does nothing (luckily, it unlocked the driver's door ONLY this morning).
    Passenger lock unlocks individually, but doesn't do anything else.
    Trunk lock cylinder is frozen, so I need to replace it. This is a pre-existing condition, but means that without central locking, I can't get into it.
    Troubleshooting steps:
    I have performed the red/black wire mod to no effect.
    I have swapped the relay/central lock unit to no effect.
    There's something clearly wrong in the driver's door as the key turns pretty freely, but to no effect. I have eyeballed it from the back side, but haven't seen enough to make any kind of real judgement.
    Next steps:
    What should I do? I intend to replace the lock cylinders in the doors and trunk as they are due for it. What else should I consider swapping while I'm in there?
    I'll follow up in a few minutes with video of the driver's lock cylinder if that's at all meaningful.
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
  • nomansland92
    • 1657
    my driver door does the same it turns but nothing happens but i have manual locks and if i look it from the inside it will unlock from outside. and the passenger door lock is just really stiff but does work but it would probably break the key if i kept using it. i would hate to get different locks thought and then i would have to have a different key for the locks and the ignition
    any ideas?
    IX being restored here
    Ix turbo build here
    • ///M42 sport
      • 3952
      could be failure of the linkage from the lock cylinder?
      • nrubenstein
        • 3148
        I can't seem to unlock/lock the door from the inside, either.
        • MaxBell
          • 1391
          I am having some serious issues as well. I washed the car the other day, had a cold weather snap and the thing froze solid. Now that it is warm again, I have lost my central locking, and all manual control of the doors. Only my trunk works.
          Let me know what you find out.
          REMEMBER: Be safe and have fun is Rule Number 1.
          The Epic Unbuild of Clint Eastwood
          • nrubenstein
            • 3148
            At this point, I'm basically just going to take everything apart and throw some parts at it. It sounds like the issue is the driver's door lock actuator. I'll replace that and rebuild the lock cylinder. And replace the trunk lock cylinder while I'm at it, so I don't have to deal with getting locked out of the trunk any more.
              • 34844
              there's an excellent diagnostics how to for the central locking system in the ETM
              • nrubenstein
                • 3148
                That's the next step. With the exception of the actuator, everything was on the list anyway.
                • MaxBell
                  • 1391
                  I think we're in the same boat, except that I don't have a garage to work on this shit in.
