Thinking of disconnecting the CEL light...
  • Stanley Rockefeller
    • 445
    My e30 has had this stupid light on for a while. I've replaced the following parts within the past 5 months. The CEL has been consistantly on for the past month, whenever the car is running.
    Replaced parts (all new):
    -intake boot
    -plugs
    -wire set
    -fuel filter
    -air filter
    -oil filter
    -oil
    -cap
    -rotor
    I've tried disconnecting the battery, then re-connecting it to see if I was able to reset the light...sadly this didnt' work.
    Also, I do recall having some issues with the reference wire when replacing the wires...could the wire not being plugged in correctly be causing the problem I'm facing? All other guages and the oil service indicators all work correctly.
    I've tried the stomp test, but when running regular fuel in the car with this DME, the stomp test doesn't work...only when I put the other DME with the performance chip in does the stomp test give me some readings.
  • Fidhle007
    I can fly, motherfucker
    • Oct 2005
    • 7209
    Go somewhere and have them scan it.
    '89 325is S50 Track Montser
    '04 X5 Daily/Tow Vehicle
    http://www.avarestoration.com
    http://www.myspace.com/brendanfiddle
    Click here if you want to be my zombie slave...
    http://www.youtube.com/user/Fidhle007
    • Danny
      • 14216
      Nobody asked you to be all logical and shit.
        • 445
        AFAIK We don't have places like that up here in Canadaland, esp. not free
          Which DME is it that has the light on all the time. If it is a 153, that DME doesn't support the stomp test, but anything later will. If the problem DME is a 173 or later, the light being on all the time and the stomp test not working sounds like a bad DME.
            • 34847
            the light grounds to turn on, so if it wasn't hooked up it wouldn't turn on at all, unless you accidentally grounded the other end.
            • StereoInstaller1
              GAS
              • 22679
              We really need to set up the software that runs this forum in such a way that you can't post in this section at all unless you specify what year/model/engine and such your car is.
              "My E30" is kinda vague, y'know?
              Closing SOON!
              Thanks for 10 years of fun!
                • 445
                Sorry guys, I have an 88 325ism with the stock m20 setup.
                For the DME I have 2 different 173's. One with the perf chip, one with the stock chip.
                thanks in advance
                • ChaseN
                  • 709
                  thanks in advance
                  Have you tried swapping them to see if the light goes out?
                  1991 318iS
                  1992 911
                  2006 330i 6-Spd ZSP people hauler
                  Gone:
                  1989 M3 S50B32, 6-Spd
                  1990 325ix 5-Spd
                    • 445
                    Not yet...I'll put ths stock chip in the other DME and see if it makes a difference.
                    thanks in advance
                      • 34847
                      why not just swap DMEs?
                      • Fidhle007
                        • Oct 2005
                        • 7209
                        Yeah, I'd leave everything closed. You don't want to go fucking up your good ECU also... Just run the chipped one and see if the light still comes on.
                          • 445
                          Fair 'nuff, I'll wait till this tank runs dry, fill with prem., then change DME's
                          I'll update you after i swap em
                          • StereoInstaller1
                            GAS
                            • 22679
                            Did you test your 02 sensor?
                            Closing SOON!
                              • 445
                              no, but I did replace it a little while ago
