Adjusting timing?
  • silversleeper
    • Mar 2005
    • 2032
    Adjusting timing?
    How do I adjust the timing, or at least, check the timing in my 1989 325i? Is the timing electronically controlled? Did I just waste money on a timing gun? Someone fill me in here, I couldn't find anything in the search.
    Claus Luthe is my hero.
  • DaN
    • 1265
    It's not adjustable, the dme does it for you.
    You can check it though, i believe.
    • silversleeper
      • Mar 2005
      • 2032
      just trying to find the spot to point my timing light at
      • gstuning
        • 833
        should be on the vibration damper in the front,
        Gunni
        @ Prodrive / Aston Martin Racing
        • loudes13
          • Dec 2004
          • 35
          how does the dme figure out cam position? I don't know if it reads crank position or has a speicific cam sensor. you could 'adjust' that sensor. aftermarket software is probably pretty max'd out timing wise, so it would be pointless - no pun intended.
          www.allenskillicorn.com
          • rs4pro3
            • 5808
            There is a toothed wheel on the crank it reads, and then reads when the #6 plug fires so that gives the ECU the info it needs.
            85 325e 2.7 ITB'd stroker
            • new2bmw
              • Oct 2006
              • 387
              timing
              how do i remove that toothed wheel so i can get to my timing belt?
              thanks
              Larry
              • NC325iC
                • Mar 2004
                • 6565
                the toothed wheel is the harmonic balancer, it unbolts with either 8 or 6 bolts takes a little force to get it off, and sensing the #6 wire isnt required for the engine to run
                • dark89e30
                  • 263
                  That sensor is definitely required for the engine to run. That is the only way that the ecu has any information on the rotational location of the engine. All it will do is crank. Found out the hard way...
                    • 37833
                    thanks
                    Larry
                    If you have a 318i [like your info shows] then you do not have a timing belt, you have a chain.
                    Grover Beach, California
                    BimmerHeads.com
                      • 37833
                      He said the car will run without the impulse sensor on the #6 plug wire, which is 100% true.
                      Obviously the car will not run without the crank sensor.
                      BimmerHeads.com
                      • NC325iC
                        • Mar 2004
                        • 6565
                        yeah i knew that, i found that out how you say "the hard way" as well
                        • dark89e30
                          • 263
                          Oops. I was still kinda drunk this morning...
                            • 37833
                            Haha, good enough excuse for me. ;)
                            BimmerHeads.com
