doing guibo job
  • EtaSport
    • 2853
    #31
    yes you can put the bearing on without a press. You have to find something to sit on the bearing surface (not the race) and just tap on it with a hammer. You will know if you got it or not because if you can't put the c-clip in, you didnt get it far enough.
    that guibo is trash, you should be able to remove that vibration damper.
    And pre-load on the csb is basically putting tension on the rubber housing. You will see the two bolt holes where you would attach to the car are slotted. Put the bolts in and then move the entire housing forward (toward front of car) and with tension still on the housing, tightend the bolts. If you dont do this, it may vibrate.
    Old and improved:
    • Digitalwave
      is a poseur
      • 6283
      #32
      Originally posted by zandi
      i got it out, there were some spots to put a wrench through it, im just really hoping that i marked the driveshaft to the tranmission right because this 'vibration damper' changed things up a bit
      It doesn't matter if you mount the drive shaft to the tranny the same way. The only thing you have to worry about it putting the splines back in the same place if you separate the 2 parts of the drive shaft to mount a new CSB.
      RISING EDGE
      • zandi
        • Apr 2004
        • 602
        #33
        :shock: The write-up I read from pelican parts didn't mention marking the splines to the rear driveshaft, so I didn't...wow
        I did seperate it and Iput it back and drove it, all seems ok but now you have me really worried, shit dude what should I do?
        • Jand3rson
          • 37587
          #34
          Your driveshaft is most likely now on it's way to being pretty unbalanced. When a driveshaft is balanced, it's obviously done with the two halves of the driveshaft put together. Hence if they are separated, and not put back together the way they were when it was balanced, it's going to be out of balance.
          • 325is_e30
            • 567
            #35
            that happened to me and it caused my brand new csb housing to crack in half within 2k miles
            • Jand3rson
              • 37587
              #36
              Yup. If your driveshaft hasn't already started to shake/vibrate, it probably will soon.
              • Matto
                • Jan 2004
                • 800
                #37
                If you unbolt the driveshaft from the guibo then unbolt the center suport bearing from the car and the rear transmition mounts you can get it all apart pretty easily.
                • Jand3rson
                  • 37587
                  #38
                  Did you just read his first post, and then skip to the last page of the thread without reading anything in between?
                  • 325is_e30
                    • 567
                    #39
                    • Matto
                      • Jan 2004
                      • 800
                      #40
                      I thought i read it all, i even made a pont too but im not sure, dang my brains need for sleep... :oops:
                      Edit: okay I just read it all again and WTF? I just said how I got my guibo off more easily.
                      • zandi
                        • Apr 2004
                        • 602
                        #41
                        So what am I supposed to do at this point to get it balanced?
                          • 34839
                          #42
                          you could take it to a driveline shop and have them try to find the balanced orientation of the two halves, or just pay them to rebalance it. personally I'd rather have the factory balance, I had a custom shaft made once and even though it was "balanced" it vibrated like a mofo.
                          • zandi
                            • Apr 2004
                            • 602
                            #43
                            Why wouldn't this write-up mention it?
                            http://www.pelicanparts.com/bmw/tech...ft_Bearing.htm
                            Why?? It would have been nothing to mark it, it really pisses me off they could leave something like that out
                            • Jand3rson
                              • 37587
                              #44
                              That write-up is for an E36.
                              • zandi
                                • Apr 2004
                                • 602
                                #45
                                still has those same splines though
