Best choice of chip?
  • silverblades181
    • Nov 2004
    • 222
    #31
    What's the difference between MarkD's chip and Jim Conforti? And is MarkD situated in the US or Canada?
    E30 325i 1990 (Winter beater)
    E36 M3/4/5 1997 (Futur IP car?)
    BMW Club of Quebec
    • King Luis
      • Sep 2004
      • 737
      #32
      markd is in canada (toronto area)
      i want to get my injectors and afm before i get the chip...when i got everything, time for the install and tune.....hope gas prices drop next year...they better go back to normal....60 cents normal.
      what is the 4.10 diff from? whats the difference from a 3.73 or so...acceleration diference???? topspeed difference????
        • 34844
        #33
        don't hold your breath.
        • Mystikal
          Wheel Fitment Expert
          • 9602
          #34
          Originally posted by robert325is
          wow... it took me like 5 min.
          i got the 91 chip, just because some places don't have 93 when i go on road trips.
          I keep the stock chip in the ashtray. If it really takes you 5 minutes, then I don't see why the 93 chip would have been a problem.
          • KeeperJones
            • 240
            #35
            1. pull battery cable
            2. remove two phillips screws and 2 plastic screws from glove box cover
            3. remove four 10mm bolts
            4. remove connector
            5. straighten metal tabs
            6. remove four small screws from ECU cover and remove cover
            7. remove plastic chip cover
            8. remove chip
            9. install new chip and re-assemble
            Five minutes? Maybe twenty minutes, at least for me. I was trying to be real careful and the pelican info did not mention the four small screws on the top, so I was trying to figure out which of the remaining screws were holding the cover on. I am very happy with the improvement and there has been no pinging with the 92 octane.
            • Budget Beater
              • Aug 2005
              • 230
              #36
              hello guys,
              I am new to these forums but i would like to chime in. I purchased one of these "generic" chips off ebay and was skeptical at first but i figured what the heck its only $35. i tried it and I am very impressed. I have no basis for comparison to other chips but it seems to be working well.
              2cents
              • KeeperJones
                • 240
                #37
                It probably works well because chances are it uses code from a "real" chip. Most of those guys buy a "real" chip and a chip burner, rip the code and they are in business. So you probably ended up with a JC or Dinan or some other legit manufacturer's chip code. I guess that is the only real issue I would have, is you don't know what you have. Luckily it worked out for you.
                After doing the research on chips, I knew exactly what I wanted. It is pretty easy to find very high praise for MarkD's chips in this forum.
                • nefarious7907
                  • Jan 2005
                  • 1170
                  #38
                  Where can I find a Mark D chip? for an ETA
                  http://www.cardomain.com/ride/657387
                  • robert325is
                    • Aug 2004
                    • 1171
                    #39
                    im talking 5 min once i got the ECU out.
                    • Mystikal
                      • 9602
                      #40
                      Meh, the entire process takes me less than 5 now. ;)
                      • napabavarian
                        • Jun 2008
                        • 834
                        #41
                        Originally posted by palmfish
                        Can someone recommend where to go to find a 4.10 LSD for my '88 325is, and how much I should pay?
                        Also, if and when I install it, is there a market for my low mileage (125,000) 3.73 LSD?
                        I just bought a $300 318is for the 4.11 8-)
                        This place is like catholic school, 2/3 of the students smoke weed on a daily basis, but the faculty seems to convince the outside world that drugs are just in the other schools, the resident pot dealer thinks he's cool because he has the originality to call anyone he doesn't like a homosexual, and most of the little children follow him like sheep, then there's the few with brains, you hardly ever hear from them, perhaps don't even know they exist, but they get all the sh!t done.
                        • SpecM
                          • Oct 2005
                          • 4531
                          #42
                          and?
                          1989 cirrisblau-metallic 325i
                          • napabavarian
                            • Jun 2008
                            • 834
                            #43
                            Originally posted by SpecM
                            and?
                            It was cheaper than buying just the 4.11
                            • SpecM
                              • Oct 2005
                              • 4531
                              #44
                              and?
                              you know that the 318is has a small-case diff that's almost useless in a six-cylinder carl, yes?
                              • tjts1
                                • May 2007
                                • 1851
                                #45
                                and?
                                Bull shit. Page 5
