slow 325ic auto
  • redbull 325is
    • 7472
    slow 325ic auto
    i know this car is going to be inherently slower than my 88 325is.. but its really really slow. I has all new filters, t-belt, hoses, mobil synth oil, trans does not slip... but its very very slow. also if i floor it (foot to the floor) it will not hit redline or even close (shifts @ 4-5k rpm) is this normal behavior? also.. this is a 1990, so i assume it has the 4.10 diff, right?
    Let me know
    Julien
    1990 325ic auto
    Build Threads:
  • Digitalwave
    is a poseur
    • 6300
    It should indeed have a 4.10, and it should get up to around 6,000 rpm. Are you sure you are pushing the pedal down all the way? Automatic's have a "kick down switch," the pedal would go all the way down unless you press extra hard and depress the button.
    RISING EDGE
    • Erick
      Official R3V Drifter
      • 11169
      Like TJ said there is the kick down switch. However I'm pretty sure you figured that one out.
      Beyond that... all I can tell you is that they really are that slow. :roll:
      ..::Support FullOpp::..
      FullOpp Stickers for sale!
      Feedback Thread
      • chriskb3
        • Jun 2004
        • 153
        maybe your kickdown cable needs to be tightened? or you could just do a tranny swap :)
        • redbull 325is
          • 7472
          I know about the kick down... maybe i have to readjust it
          Build Threads:
            • 34847
            stick the tranny in 2nd gear and floor it. if it still won't move then something is up.
            • AdamF 88iS
              • 2051
              You may be able to adjust the cable, but I'd bet the mechanical limiter inside the tranny is getting worn out, pretty common when they get some miles on them.
              Adam Fogg- '88 M3
              Common sense- It's the new 'gifted'
              • 92 mtechnic cabrio
                • 4907
                have a friend race you in your normal manual E30 vs you in ur auto, or vice versa.
                if either one of the car pulls 2 CLs on each other, then theres a problem.
                my automatic cabriolet can keep up with a stock 5-speed coupe easily because of the 4.10
                R.I.P 07/01/09 - 04/23/10 :(
                • Stu Mc
                  • 4083
                  Not a chance
                    • 4907
                    Not a chance
                    yeah huhhhhhh
                    okay well not easily, but hes not going to walk away until like 65 or 70
