How to change timing chain tensioner?
  • Bimmerfanatik
    • May 2004
    • 5349
    Forgive me, but I'm an M20 guy. Seems to me it's an easy job, and doesn't take long. Can anyone explain what it is, where it is, and what's involved in swapping it? Searching didn't help.
    Also, the car has a rough idle, but revs beautifully. What could be causing this? I was thinking it's the tensioner, and at higher RPM the slack in the chain is removed, causing the engine to sound better. Just a theory from what I understand of the M42.
    • 34844
    the rough idle is likely a vacuum leak. check the intake boot for holes/cracks and check all vacuum hoses.
    • Bimmerfanatik
      • May 2004
      • 5349
      It sounds real rough though, almost like it needs a valve adjustment or is low on oil. but i seem to remember that you can't adjust the valves on these...
      • demlotcrew
        • May 2004
        • 297
        But i would not put the tensioner in and run the engine to 3k for 20sec. Release the tensioner in a clamp and put it in by hand with a 17mm spanner.
        A
        Andrew AT E30zone.co.uk | H23-is | S14
        • Bimmerfanatik
          • May 2004
          • 5349
          Originally posted by demlotcrew
          http://www.esatclear.ie/~bpurcell/318isfaults.html#timingchaintensioner
          A
          Thanks for the help and the advice - it's definitely an easy job.
          • Rob
            • 8166
            fucking hell, why dont people use the proper forums?
            BEERTECH
            • RobertK
              Kicked cancer's ASS.
              • Jun 2005
              • 5864
              All depends on how fast you want people to reply to your post. There are so many sub-forums on here that posting in them gives you very little exposure so you end up waitng days instead of hours for replies.
              • hamann318is
                • 3382
                A
                I did the 3k for 20 seconds. No adverse affects, but you're going to get a very scary sound if you do it that why when trying to start it. The car will be fine though.
                The BMW 318 is back. With a vengeance.
                • kowalski
                  • Jan 2005
                  • 1791
                  yeah it scared the shit out of me.
                  • Bimmerfanatik
                    • May 2004
                    • 5349
                    can I get a
                    seriously.
                    • kowalski
                      • Jan 2005
                      • 1791
                      out of curiosity how long did it take you to find that picture to add in to your post?
                      • Bimmerfanatik
                        • May 2004
                        • 5349
                        10 seconds.
                        Search the world's information, including webpages, images, videos and more. Google has many special features to help you find exactly what you're looking for.
                        search->images-> hallelujah amen
                        first result, right click, properties, copy image address, post here.
                        • kowalski
                          • Jan 2005
                          • 1791
                          thats funny
