Injector question
  • Tinman
    • May 2004
    • 58
    Injector question
    I have installed 19 lb injectors in my 325is and now my wideband oxygen sensor is off the chart. Does that sound normal? It is reading consistently in the 20's. Prior to these injectors it was at 14. Is this part of the process until the computer learns? :?
  • Digitalwave
    is a poseur
    • 6299
    Doesn't surprise me. According to all the people with 19 lb injectors and no A/F gauges or dyno time, it should adjust. Please keep us updated on the results.
    RISING EDGE
    • nickmp0wer
      • 1427
      unplug your battery overnight then the ecu should be able to learn a lot faster, i think
      • Mystikal
        Wheel Fitment Expert
        • 9602
        Don't we all love R3V?
        Robert's car ran rich with 19lb injectors, Dave's cabby ran rich...
        • RCWells
          • 3589
          ARRRRRGHHHHH!!!!!! The INSANITY!!!
          so which is it? will it run rich, or NOT?
          I have yet to install mine because I am waiting to settle my air flow issue, but this is getting ridiculous.
          [THE 501 club - Founding Member]
            • 34844
            so how do you explain my fuel economy? I went from an average of 20-21mpg to 21-22 (slight increase). if it were running rich wouldn't it drop? and shouldn't there be black soot all over the back of my car, and shouldn't it smell bad? (I've had carb'd cars, I KNOW what running rich smells like)
            and yes, I love r3v. all the guys who haven't done this seem to know all about it. :roll:
            p.s. it only takes a minute or so for your ECU to reset after you unplug the batter, overnight is uneccesary.
            • Digitalwave
              is a poseur
              • 6299
              Chris, you have never had your car on a dyno or hooked up to a wide band O2 sensor so you don't know what your A/F ratio is regardless of your fuel mileage increase. The A/F charts I have seen for cars that simple bolt on injectors are less than ideal, and thats why I haven't done them yet.
              RISING EDGE
              • screamingbmwe30
                • Jan 2005
                • 415
                if its reading 20 instead of in the 14's it is reading lean there chief. not rich. lower than 14.7 to 1 would be richer. ;)
                • Mystikal
                  • 9602
                  No one wants to prove me wrong, all I can work with is the dyno A/F charts posted. And on both cars with these injectors and no fuel management, they ran rich.
                  I can only add up the actual proof given to me, no more.
