HELP: E36 P/W switch install on E30
    Originally posted by schtozo View Post
    Try this
    thanks, I will try this.
    89 E30 S52
    Transaction Feedback.
      Originally posted by gtarwiz View Post
      Do you have the right brown wires connected to the right wires? When I did this, I did the mistake of cutting all wires off my body harness and not one by one and it does matter which brown wire goes to what wire.
      In my case both brown wires from the e30 plug did the same thing so i connected the e36 negative to one of them only. I had only 4 wires from the e36 switch though not 5 like in this case. I assume that the second ground from the e36 switch is the bulbs ground?
      One of the best threads you will ever read
      http://www.r3vlimited.com/board/showthread.php?t=221813
      Nice trailer of my e30
      http://www.youtube.com/watch?v=TTjtG...e_gdata_player
      If i sold you something please leave feedback here
      http://www.r3vlimited.com/board/showthread.php?t=217142
        Not quite sure but I do know that it didn't work for me when I had them switched.
        BMWCCA # 482566
        Originally posted by nando
        also, I can't think of any BMW special tools you need to do a headgasket on an M20. you could nearly do it with the trunk tool kit, some bubble gum, and string.
        Check out my Leather Shift Boots for Sale Here
        Check out my other work with my GF Here Great gifts for your Wife or GF
          i keep blowing the fuse with this set up... hmmm...
          89 E30 S52
            Are you sure you identifyed the e36 switch cable colors right? The e30 diagram i gave you is correct so maybe you got the wrong diagram for the e36 switches.
              that's what i need help with.
              the attached the negative of my power supply to the black on the switch and red on my tester. Here are the results:
              89 E30 S52
                Where are
                all the smart people?
                89 E30 S52
                  Never mind, guys. I got it to work. Thanks for all the knowledge.
                  Yes, it was the 2nd ground that threw me off.
                  89 E30 S52
                    What did you do to make it work? Having the same problem of blowing out fuses
                      Same write up but with pics
                      Continuous For Sale Thread
                      323i s50
