Guibo looks shot... but would it rattle? *pics*
  • Digitalwave
    is a poseur
    • 6300
    I was checking for what was wrong from this thread, and I found my guibo was very cracked and might even look broken in some places. After reading that thread, do the symptoms seem to line up? Because while I could see the guibo causing the vibrations I have, it doesn't seem like it would make the loud clunk/rattle sound. Could it possibly be the center support bearing as well? I hope not, since that's $50 and I am broke as a joke...
    Does an automatic 325i need the 110 or 96mm guibo?
    Thanks in advance.
    RISING EDGE
  • rwh11385
    lance_entities
    • 18403
    Re: Guibo looks shot... but would it rattle? *pics*
    .........Does an automatic 325i need the 110 or 96mm guibo?
    :roll: It's fate TJ.....it's telling you this is the time to swap. ;)
    • Jonathan M3
      • 1837
      The original guibo on my car was in worse shape than that and it didn't cause any wierd noises/vibrations, but who knows. Then again, that same guibo also "blew up" one day when I was doing about 130mph, so I'd highly recommend changing it regardless. ;)
      '05 E46 M3 Imolarot/Cinnamon - CURRENT
      '98 E36 M3 Estorilblau/Dove - SOLD
      '90 E30 M3 Brilliantrot/Black - SOLD
      SRS BSNS Motorsports - 24hrs of LeMons Racer
      • Digitalwave
        is a poseur
        • 6300
        I actually have a lead on a tranny swap kit for dirt cheap.
        RISING EDGE
        • Ryan Stewart
          I Love Miatas
          • 8978
          Then I'd just do it then......
          Im now E30less.
          • Digitalwave
            is a poseur
            • 6300
            I won't be able to at least until spring break, I need my car to drive back to school on Tuesday.
            RISING EDGE
              • 34847
              that looks pretty trashed to me.. I bet it's responsible for at least some of the noise. my guibo's look brand new (one of them is).
              • Digitalwave
                is a poseur
                • 6300
                I guess I will change it and see what happens...
                RISING EDGE
                • rs4pro3
                  • 5808
                  It could cuase some noise as the tranny has a metal pin that slides into the end of the driveshaft. If the Guibe is bad the driveshaft could flex around some and hit that metal pin. Just and idea but that might be it.
                  85 325e 2.7 ITB'd stroker
                  • darien28
                    • Jan 2004
                    • 240
                    should change the driveshaft center support bearing while you're at it since i'ts going to be removed when u change the guibo... might as well do your tranny mounts too.
                    Just read your clunk problem post, and I used to have a clunk from the rear... it all went away when I changed my guibo and center support bearing... dunno why it clunked, but changing the 2 parts fixed the clunk.
                    • Digitalwave
                      is a poseur
                      • 6300
                      It was my damn wheel... I think it threw all the weights and was wobbling enough to make that noise.
                      RISING EDGE
                      • 318daily
                        • 507
                        yes, the CSB will cause a clunking sound. My new CSB cost around $25, i'd call around.
                        • Kavkazia
                          • 394
                          When I first got my e30, it had bad center support bearing, and it was vibrating car really bad.
                          95' M3.
                          90' 325i Turboed.
                          87' 325eS Fixed.
                          • Werksmini
                            • 1658
                            haha, I had the same thing happen except it was ice and snow build up in the rear wheels. It shook like mad on the highway untill I found out what it was. Good stuff.
                            I bombed Korea every night.
                            • Digitalwave
                              is a poseur
                              • 6300
                              The symptoms were so bad, I can't believe it was a wheel!
                              RISING EDGE
