"Fan delete" kit availible for E30?
  • Digitalwave
    is a poseur
    • 6282
    So change your thermostat then, there are 3 temps for E30's, 71, 73, and 80 I believe.
    RISING EDGE
    • bimmer8604
      • 3017
      Why change your thermostat?
      Kyle
      1988 M3, 97 840, 99 XJ
      DILLIGAF
      • Budget Beater
        • Aug 2005
        • 230
        it allows the car to start cooling earlier and also stay cooler however u don't want to let it run too cold b/c then its not good for optimum performance. you can usually go one step down, (so from like 80-73, or 73-71 and etc). this allows you to run that and lower fan switch which enables you do not need mechanical fan anymore.
        • hamann318is
          • 3382
          Not that it matters, but the M42 uses the 88 temp thermostat.
          The BMW 318 is back. With a vengeance.
          • bimmer8604
            • 3017
            Well think about it this way. If you put in a cooler thermostat, your coolant is going to start flowing into your radiator at a lower temperature, therefore not enabling your motor to reach optimum operating temperature. Also, since you have a lower thermostat in you coolant is always going to be circulating, not giving it enough time to cool down, thus resulting in your motor actually running hotter than you want it to. I guess what im tryiing to say is ultimatley your motor will actually run hotter, because you arent giving the coolant enough time to disipate its heat. I think I am going to leave the current thermostat in the car.
            Kyle
            DILLIGAF
            • parkerbink
              • Jun 2004
              • 10137
              The fan unmounts from the condenser and has no real mounts I am going to remove the rivets on the mounts on the condensor & make a mount. Damn this thing puts out some serious air!!!!!
              I tried connecting power to the connector but no go, when I connected directly to the back of the fan it went!! Does that mean the resistor is bad or do I need to connect the red & brown wires to a relay & black to ground?
              Gracias!
              • AndrewBird
                The Mad Scientist
                • 11898
                Gracias!
                Hook black to ground and then the red and brown wires are either two different speeds or forward and reverse. Hook power to the red and brown wire. Should work.
                My 5-10HP comment was a general statment about any engine. Different engines will gain more then others and vise versa.
                • Jordan
                  • 12908
                  Originally posted by NitroRustlerDriver
                  Jordan was running without a fan for a long time in corvalis and he never had any problems. I think he put it back on though for in Texas. It's a bit warmer down there.
                  11 and a half months. I have the coldest tstat, forget the temp. My car always ran a needles width past 1/4. Took about 5mins from that temp, sitting still, to reach half. Went up QUICK after that.
                  So long as you don't wind up in a parking lot on the highway you are fine.
                  https://mtechniqueabs.com/
                  • Budget Beater
                    • Aug 2005
                    • 230
                    Kyle
                    depends on the ECU, the E36 ecu cutoff was 80C before the ECU started dumping fuel to warm up the engine, but its stock thermostat was 88. thats why i said that comment, so you are correct b/c i tried 72 on my E36 and it ran like crap. so one step down as i mentioned is ok .
                    • mspiegle
                      • 1026
                      That's without an electric fan, right?
                      Michael Spiegle
                      '01 Ford Escape / Daily Driver
                      '99 M3 / Track Car
                      '87 325is bronzit / wtf car
                      '06 Daytona Triumph 675 / Daily Rider
                      • PeaveyBassist
                        • Sep 2004
                        • 3511
                        ^^^ Yes, thats right. Jordan didnt use any sort of fan.
                        Will
                        RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
                        Welcome e30 (brilliantrot '90 325is) 12/23/06
                        DaveCN = Old Man
                        My signature picture was taken by ME! Not by anyone else!
                        If people keep quoting me in their sig, I'm going to burn this motherfucker down.
                        • nefarious7907
                          • Jan 2005
                          • 1170
                          I think that I am in need of a cooling system overhaul, mine starts at half and goes to three quater, then again when my lower radiator bushing popped out and my fan had two blades stuck into my radiator I guess that didnt help things. going fast on a mock track and hitting a track style curb hard will jar things loose.
                          http://www.cardomain.com/ride/657387
                          • Budget Beater
                            • Aug 2005
                            • 230
                            FYI guys, im looking for "Custom" application of universal aluminum racing radiators on ebay. One of my E36 buddies used a 19"x26"x3"thick radiator on his E36 in place of his stock plastic radiator and he said he could run zero fan even with stock thermostat and fan swithc and car never ran warm ever, the cooling capacity and efficiency was greatly increased. they are about $170 on ebay. just throwing out idea's here and there.
                            • thejimlab
                              • Oct 2004
                              • 588
                              why not just get one of these?
                              • nefarious7907
                                • Jan 2005
                                • 1170
                                Originally posted by thejimlab
                                summit and jegs have them cheaper than that and lower profile. also take into consideration cfm's but if others are running without fans than cfms shouldnt mean that much.
