325ix - Leak in trunk
  • vertdust
    • May 2011
    • 70
    It rained a bit on the east coast last night, and this morning when I popped open the trunk, I noticed a bit of water trickling from the rear opening where the battery wire is being funneled through (right side of trunk). any ideas here?
  • StereoInstaller1
    GAS
    • 22679
    First guess? Window sail trim grommets
    Closing SOON!
    Thanks for 10 years of fun!
    • Kershaw
      • 11822
      ^ only thing that would explain a leak in that location.
      AWD > RWD
      • Ceeker
        • Sep 2009
        • 2821
        ^ not necessarily. check to make sure your sunroof drip rail hose is connected behind the headliner. Water can drip down and find it's way into the trunk if it's not connected, partially connected or rusted out where it is connected.
        • StereoInstaller1
          GAS
          • 22679
          ^agreed, but am sticking to my guess. Gutters are easier to test, thats for sure.
          Closing SOON!
          • ZM Blue Devil
            • Dec 2006
            • 13836
            Second the window sail, if it was the sunroof drain it would be in the wells.
            Levent
            %20levent@gutenparts.com
            Ladies:
            • vertdust
              • May 2011
              • 70
              thanks. just so i'm clear, the window sail is this long silver strip (orange arrow)? I was peeking around the area where the "green circle" is located, and see possibly some areas of concern (gaps that go inward). whats the best way to fix these? replacing these grommets? or would I just fill it with some sort of liquid filler?
              • Kershaw
                • 11822
                replace the grommets!
                AWD > RWD
                • nomansland92
                  • 1657
                  Mine leaked there, it was the from the rubber hose in the wheel well under that plastic cover. I think it's a breather for the gas tank or something I forget.
                  IX being restored here
                  Ix turbo build here
                  • Kershaw
                    • 11822
                    the rubber hoses inside the trunk, behind the mousefur, are the drains for the sunroof.
                    AWD > RWD
                      • 34844
                      there's one for the battery vent too.
                        • 34844
                        Originally posted by ixmachine
                        having the same issue. it's been raining alot the past weekend. does anyone have the part number(s) for the window grommets?
                        www.realoem.com
                        • audiquattrot
                          • May 2008
                          • 3836
                          I have the grommets & gaskets you need (3 on each side) + side vent gaskets if you need them. I work in NJ.....where are you located?
                          www.instagram.com/snwmble
                          #snwmble
                          Current:
                          '05 BMW M3 - Silver Grey/Imola Red
                          '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
                          '15 Mini Countryman - Blazing Red/Carbon Black
                          Past:
                          '01 Audi Allroad - Light Silver/Platinum Saber Black
                          '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
                          '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
                          '90 BMW 325i - Schwarz/Tan sport *Sold*
                          '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
                          • OttoBob
                            • Dec 2010
                            • 88
                            I think I could have the same problem. I get water in the rear floor area behind the driver seat after it rains. My "window sail" seems to be slightly pulled away from the body and is a bit loose. Is it difficult to take things apart in this area and replace the needed grommets/gaskets etc.?
