fitting a Motometer cluster.
  • BMC227
    • Apr 2011
    • 448
    Hello All,
    has anyone ever installed a Motometer cluster into an e30 that has a VDO cluster?
    The connectors are pretty much the same and plug in, i tried a Motormeter cluster earlier and everything worked fine except for the tacho/rev counter. Is there any info on this? please let me know. Cheers.
    They call me the frog
    - E30 Alpina C2 2.7
    - E30 Alpina C2 2.5
    - E28 M 528I 3.5 (300HP)
    - E36 M3 S50 3.2 (Euro)
  • AndrewBird
    The Mad Scientist
    • 11898
    VDO/Motometer clusters are interchangeable. The only variance is from early model to late model. More here:
    • E30_fiend
      • Apr 2006
      • 7348
      ^^^^^ this
      • BMC227
        • Apr 2011
        • 448
        Still doesn't help me.
        - E30 Alpina C2 2.7
        - E30 Alpina C2 2.5
        • reelizmpro
          • 9516
          u sure the cluster is good?
          88 M3 - LACHSSILBER/SCHWARZE
          • BMC227
            • Apr 2011
            • 448
            - E30 Alpina C2 2.7
            - E30 Alpina C2 2.5
            • Killacortes
              • 1937
              You paid a grand?!!?
              r3v does not fuck around. First you get banned, then they shoot you
              • BMC227
                • Apr 2011
                • 448
                b
                - E30 Alpina C2 2.7
                - E30 Alpina C2 2.5
                • dogsbark26
                  • Nov 2008
                  • 533
                  Are you using the proper coding plug in the new cluster for your engine?
                  • dnguyen1963
                    • Nov 2011
                    • 2648
                    You need to transfer the white coding plug over to the new cluster for the tach to work.
                    • nomansland92
                      • 1657
                      http://www.r3vlimited.com/board/show...05&postcount=6
                      So after I've read this it makes it sound as the gears are all the same as well. I have an 88 motometer and the replacement gears are over $60 and vdo gears are cheap, I was always told that the gears have a different teeth count and they couldn't be interchanged.
                      I don't maybe i misunderstood the article but it would be appreciated if someone could clear that up for me.
                      IX being restored here
                      Ix turbo build here
                      • bmwm42
                        • 6300
                        gears are different from vdo and motormeter they are not interchangeable the clusters themselves are interchange from early to later model it makes no difference aside from the coding plug requiered from a 6 or 4 cyl.
                        Originally posted by bmwm42
                        PNW vulture pm me for parts
                        Strategic nw e30 command
                        • mbonanni
                          • Sep 2011
                          • 6236
                          do you have early model or late model?
                          check the coding plug to make sure it is in the right years.
                          I have an early model coding plug i could sell you pretty cheap if you want to try it or need it.
