clutch saftey switch
  • e30fromroyalston
    • Jul 2011
    • 18
    just got done my 5 speed swap. I thought i could just pull out the auto brake pedal and not remove the pedal box. Everything went real smooth until i discovered the auto pedal box doesn't have the tab welded on it for the clutch return spring. So I had to replace the whole thing. Anyway, my question has to do with the wiring of the clutch saftey switch. It doesn't appear there is a connector on the harness. I was wondering what the best way to tap into my auto harness to hook up the switch. I've been having a reoccuring dream that my girlfriend cranks over the car and crushes my front valance. Hopefully i can avoid that turning into a reality by hooking up the switch.
    The clutch switch, as I recall, doesn't disable the starter. It is used to turn off the cruise control. There should be a two pin connector with a jumper tucked above the pedal box for the clutch switch.
    • devon.818
      • Feb 2011
      • 2937
      definately doesnt disable starter!
      on the 3 5sp e30's i've had, i have had a few "jumps" when forgetting its in gear..
      they start in nuetral too, so yeah no switch.
      • Sagaris
        • Sep 2009
        • 2243
        This is good to know. I removed my cruise control and was going to ensure this clutch switch was wired up correctly. Now I think I will just remove it. Its a few grams of weight reduction !:hitler:
        • TobyB
          • 5264
          heck, even an earlier E36 will start with the clutch out...
          t
          • atmobenzin
            • 151
            Is there a car with manual that doesnt?!?!
            • e30fromroyalston
              • Jul 2011
              • 18
              my 88 toyota pickup has a clutch start cancel switch. thanks for the reply dudes.
                • 34839
                any BMW basically after the E36 (and even most of those, if not all) has a clutch interlock switch.
                • dnguyen1963
                  • Nov 2011
                  • 2649
                  I have driven stick all my life and all the cars require the clutch depressed before starting. My '88 325i can be started w/o depressing the clutch...scare the hell out of me until I read up on the topic.
                    • 37832
                    Guess the Germans assumed the drivers of their cars actually had a brain.
                    Classic BMW Specialists
                    Grover Beach, CA
                    www.BimmerHeads.com
                    • AndrewBird
                      The Mad Scientist
                      • 11898
                      :ohsnap:
                      • atmobenzin
                        • 151
                        I guess it must be different over here as I have never seen such a thing in my life. Cousins e46 did not have one, her current e60 doesnt have one, even old mans 08' land cruiser doesn`t have one.
                          • 34839
                          uhm, yes they do, or they were all automatics.
                          • atmobenzin
                            • 151
                            All of them manuals
                              • 34839
                              I gaurantee they have clutch switches. EWS and the DME won't work without it.
