Tighten all the bolts for the wires on the starter solenoid. It'll take 5 minutes. You can get to them by reaching your hand right behind the brake master cylinder resevoir on the driver's side of the engine bay.
car wont start!
first off, a battery is a battery. as long as it has 12.6 volts and posts that fit you car, it'll work
2nd, if you can start the car by jumping the pins, the starter is fine and its your ignition switch that's the problem. or in your case an ignition kill switch. you could also push-start it
3rd, go buy a multimeter. even an el-cheapo model as long as it has voltage, resistance, continuity, and ground checks. i have the harbor freight special and its been well worth the $3 i spent on it.James
'88 M3Comment
Originally posted by uflnucengwhat kill switch? Sorry for the new battery, but if it turned when you connected pins 11 and 14, then the starter is just fine.Comment
Originally posted by jht3first off, a battery is a battery. as long as it has 12.6 volts and posts that fit you car, it'll work
Proper sized battery is key. Pittsburg is known for cold weather too, so more Amps is crucial.Comment
Originally posted by uflnucengWhere was the kill switch located?
Now its time to:
get the bumpers on
get a new windshield
bleed the brakes
new power steering fluid
oil chainge
diff change
transmission change
more more and more
Originally posted by uflnucengAre you freaking kidding me??!?!? I'm going to have to swing by and see this. :down:
haha its not that interesting. I was just sitting in the cockpit fiddling around with my leather ebrake boot that never likes to fit on and I noticed the switch. "don’t you dare tell me its that fucking switch" flipped the switch and turned the ignition. I was having mix feelings, I didn’t know if I should be mad or happy since it was the fuckin switch the whole time!Comment
Originally posted by Schneider325on the knee abolster. I must have bumped it one day or something.
Now its time to:
get the bumpers on
bleed the brakes
oil chainge
diff change
transmission change
more more and more
Originally posted by DigitalwaveBuy a Bentley manual. If you don't know where the starter is, I think you are going to struggle with a lot of this stuff.Comment
Originally posted by ///M PoweredGreat advice, it'll pay itself off quickly.Comment
