Cheap Sub-Frame Fix?
  • AndrewBird
    The Mad Scientist
    • 11898
    To me, this seems like a really stupid idea. At least, the idea of fixing worn out bushings. You should fix worn out bushings by replacing them, not putting a band aid on them.
    I do see however how this might stiffen the bushing up and be an improvement to stock bushing that are in good shape. But why not just go urethane and never have to worry about it?
    • BMW BMXER
      • 2325
      Let us know how it goes...
      Sold it.
      • SchnellerVert
        • Sep 2005
        • 3948
        Seems to me as thou it's half ass. Just my opinion thou. I like the analogy to the band aid too.
        • RobertK
          Kicked cancer's ASS.
          • Jun 2005
          • 5864
          But if it works then what does it matter right?
          1 hour and $24 is worth it if it saves me 10 hours and $100. Appearently it's working for others and recommended by some other enthusiasts and for $24 I don't think the guy is trying to make a killing on Ebay.
          • BMWM5LOVER
            • May 2004
            • 261
            how do u know if ur sub frame bushing needs to be changed. Anything particular to look for.
            1991 BMW ///M5 .:Black on Black:. - Modded
            1988 BMW 325i .:Zinnebarrot on Black:. - Modded
            1999 Volvo V70R AWD .:TI Silver on Black:. - Modding has begun
            1999 Subaru Legacy AWD/5 .:Green on Grey:. - Modded Rally Style
            1990 M20iS Alpwhite II- Sold
            • Axxe
              • Aug 2004
              • 3355
              Sloppy ass. Turn sharp and the rear feels disconnected. Slides become uncontrollable, no grip off the line.
              IE Urethane is the way to go.
              Keep it slideways!!
              • BMW BMXER
                • 2325
                I figure it cant make worn out subframe bushings any worse.
                Sold it.
                • BMWM5LOVER
                  • May 2004
                  • 261
                  Didn't you do this all by yourself to your car?
                  If so, how difficult awas it man?
                  I remember you mentioning something about your redone rear.
                  • Spencer
                    • 767
                    Sounds like a good idea; I never like to mickey mouse with my car though.
                    I don't think the car would pass an inspection with those :-S
                    -Spencer
                    • fporro
                      • 1859
                      they will be under those metal caps, so it would be impossible to detect my visual inspection.
                      • turnofftheradio
                        • Apr 2005
                        • 448
                        sparked my interest. def. want to know how it turns out. hopefully each peice doesn't cost $23
                        • RobertK
                          • Jun 2005
                          • 5864
                          For $23 you get the whole set to redo your bushings.
                          • Digitalwave
                            is a poseur
                            • 6292
                            It doesn't take 10 hours or $100 to do your subframe bushings. I had mine done in under 5 hours full removed and reinstallation and its less than $100, but I got mine for free anyways.
                            RISING EDGE
                            • RobertK
                              • Jun 2005
                              • 5864
                              Then your statement is still not entirely true. For someone doing it for the first time it can be up to a 8-10 hour job and if that person were to buy them it would probably cost the $100.
                              Just the thought of taking so much shit apart to fix 2 bushings is such a waste when something much easier can accomplish similar results.
                              • Digitalwave
                                is a poseur
                                • 6292
                                I did it myself, and it was my first time. The bushings new were valued at $80 (urethane) from www.bmwbushings.com, OEM ones are even cheaper.
                                RISING EDGE
