When you turn key "on", how long before relays click?
  • blocke
    • 1305
    On my car it takes roughly 6 seconds. If I try to crank the car before I hear them click, it won't fire. Normal?
    Parts Wanted
    The Never-ending Resto Mod
  • Cletonius
    • 2809
    Mine are faster than that. Do you know if they are the original 20+ year old relays?
    - Josh
    1990 325is
    Need a shift boot?
    Looking to buy shift boot frames, PM if you have one to sell
    Here's what happens when you let the internet pick your license plate
    • blocke
      • 1305
      Very likely, I just haven't had time to replace em
      Parts Wanted
      • netcsk
        • Apr 2004
        • 1609
        They should be immediate. They don't have any time relay in them.
        • b*saint
          • 3794
          you mean time delay on.
          Ma che cazzo state dicendo? :|
          • blocke
            • 1305
            Fixed
            So threw in a brand new DME relay in today, problem solved. Guess my old relay was on it's way out. Some times it wouldn't "click" period, others it took me cycling the key off and on a few times, while others it took a good few seconds to work.
            Just incase anyone else has these symptoms.
            Parts Wanted
              • 34844
              I'd reccomend to everyone with an E30 to replace any relays that are original.
              • jrobie79
                • Mar 2006
                • 2526
                are they generic radio shack relays? or should they be sourced from somewhere like blunt, bma, pelican, etc?
                1991 318i ---- 308K - retired
                • blocke
                  • 1305
                  I know the DME relay is diode protected, and the Fuel pump relay used to be 4 pin and i think was superseded by the 5-pin. I got them from BMA, but anywhere you mentioned should carry them.
                  Parts Wanted
                  • German Audio Specialties
                    • Feb 2012
                    • 374
                    First, there is no diode in the main relay. It is a STDP relay, using 2 N.O. contacts. Some forglight relays will work, simply find one that has 2 "87" terminals and no "87a".
                    Second, the other relays are all different configurations than any other "off the shelf" relay, so you cannot use a normal relay. But Blunttech, BMA, whatever should have them, but zero chance at Radio Shack.
                    X100
                    Luke
                    August R3VLimited Special: E3012 "V3" box: $225 shipped
                    Tutorials: Killer $500 Stereo | E30 Vert Dual 8'' Box Installation | E3010 Amp Rack Installation | Radio Wiring and Amp Bypass
