So I just went to smog…FAILED, Advice?
  • schröe30er
    • 121
    **Edit: It was the CAT like I said. Btw, for our cars, you can use any CAT in the 36000 series. So if you Cali guys are having a hard time finding one because we are only allowed to search by our year model, and you have a custom exhaust system. You can choose any one from that series that matches your inlet/outlet layout and diameter, and you will still be 100% legal. Whether or not it says BMW in the Application list. All the CATs from the 36000 series are tested on the same vehicle by CARB. It took three pages on here and still couldn't get an answer to that question...too funny. Plenty of engine tuning advice in this thread though, if you need that...read on.
    Hello Gentleman,
    So I just went for smog and failed...royally too. I failed the whole entire 15mph test, by a high margin. At least double HC and CO, along with high NO. Car has zero engine mods. I put a rebuilt head on it over 2 years ago and I had already passed smog once since then.
    Before the test, my car was only sitting for about 6 months while I worked on it. Considering the high numbers across the board, I figured it was the cat, the smog guy agreed.
    Question, what is the cheapest CAT I can get away with? Im not worried about CARB compliance, they don't even check that. All I care about is that it will actually work to pass smog. California people only please, unless your a CAT pro.
    I am desperate guys, I've been out of work for a year. I just borrowed like $500 to get my car finished and rolling. I have a job lined up once I pass smog. I went to the California Consumer repair assistance program website (CAP), and they aren't accepting new applications until after July 1st. So I am fucked basically, unless I can figure something out.
    Thanks for any help
    Autos:
    1989 325ic -Blk/blk 5 speed, stock weaves, hella euro smilies, PB swap, 320i trans mounts, M3 CAB's, e36 rack, Vogtland springs, Billy Sport fronts/Kyb Camaro rears, M30?
    1986 eta -Chipped, stock weaves, hella euro smilies, M3 CAB's, e36 rack, Billy HD's -L.A. traffic killer -SOLD
    1983 300D WVO since '07 my DD
    Plus more...
  • KenC
    King of Kegstands
    • 14396
    Drive the piss out of it and take it in immediately when it's super hot.
    Originally posted by Gruelius
    • schröe30er
      • 121
      I did that, would a cold cat alone cause such high numbers though? I failed by a lot...
      15mph test...
      HC MAX 108 MEAS 207
      CO MAX 0.50 MEAS 1.01
      NO MAX 767 MEAS 1056
      Autos:
      Plus more...
      • Robotin
        • Jun 2011
        • 4471
        pay to pass...
        1989 325i SETA stroker [delphin] R3V'd 8/31/2011
        1989 325ix [zinnoberrot] $OLD
        1970 2002 [Nevada]
        Originally posted by Herr Faust Schinken
        guy must have slid into something that doesn't look like a car vs car hit
        Originally posted by ak-
        Must of slid into Rob
        • KenC
          King of Kegstands
          • 14396
          A cold cat will give you high numbers. Find a place that doesn't have a line and can do the sniff immediately when you bring it in. Run the hell out of the car and make sure it's super hot.
          • schröe30er
            • 121
            Originally posted by M20_fiend
            pay to pass...
            I'm down, Where? You can PM me...
            Autos:
            Plus more...
            • schröe30er
              • 121
              Right, but that high?
              Anyway, aside from CAT, I understand what needs to be done to help pass smog, I've searched all that before. This thread is mainly about finding the cheapest CAT options for a single piped exhaust in Cali. I'm going to give her a complete tune up and re-test before I get a new CAT either way. I am just preparing for a worse case scenario.
              I read that aftermarket CAT's don't last as long, but I'm not worried about that right now. I can save up for a better Cat later. I just want to know the cheapest one that will work at least once.
              Autos:
              Plus more...
              • bernzpeed
                • 3917
                Have you heard of CRC "Guaranteed to pass smog" I used it on a newly rebuilt engine at 50miles only, it passed with flying colors. The car was non-op for 3 months.
                89 E30 S52
                Transaction Feedback.
                • schröe30er
                  • 121
                  You know what I have heard about that stuff, from what I can remember many people have had success with it. I never really looked into it though, going to now...thanks!
                  Edit:
                  After just reading the Amazon reviews, I may be sold on that stuff. Ill get the tune up first and see what happens. I do prefer to know whats going on rather then mask it. But at this point I am down for masking. With summer coming up, I need this job, and my vert!
                  Autos:
                  Plus more...
                    • 37833
                    If your car still has the OEM cat I'm willing to bet it's not bad. Saying the cat is bad is everyone's solution to not passing smog. Have you checked your plugs? Cap and rotor? Valve adjustment? How old is the gas in the car?
                    Grover Beach, California
                    BimmerHeads.com
                    • schröe30er
                      • 121
                      Definitely not the oem CAT for this car. It was switched to a
                      2.5in single pipe before I bought it. I guess it could still be a
                      BMW made CAT, but I doubt it.
                      I just had the exhaust off for other work, and the cat has a date
                      stamp on it of 2/06. So I am guessing its probably nearing the
                      end of its life cycle? I heard 6-8 years right?
                      Gas is new. New Spark plugs, Ignition cables, Cap/rotor installed
                      less then 2 years ago when I did the head, valve adjustment was
                      also done. All these things have seen minimal use in that time, less
                      then 1k miles. My WVO benz is my DD.
                      I think it may be a mixture between the CAT and maybe I need
                      to change the oil from it sitting. A new O2 sensor wouldn't hurt
                      either. I'm only replacing the cat as a last option.
                      Autos:
                      Plus more...
                        • 37833
                        If it's got a cheapo aftermarket cat (and it likely does) it's probably bad.
                        BimmerHeads.com
                        • oldmann
                          • 265
                          My problem was a combination of air inlet temp sensor, coolant temp sensor and 02 sensor. Have U pulled codes yet? New plugs and remove the air cleaner too wouldn't hurt.
                          • schröe30er
                            • 121
                            Yea, that's what I was thinking.
                            Yea I'm going to check for codes later today. Ill check the sensors as well.
                            Autos:
                            Plus more...
                            • schröe30er
                              • 121
                              So I did a stomp test, 1444/no errors. So I am leaning closer to the cat. Would an oil change after it sat for 6 months, make a hug difference in the numbers? I haven't used the oil in there that much. So it can't be that dirty.
                              I'm going to search around for a cheap cat that will work in Cali. Ill get a better one later, and just take the smaller hit now. I just need to get rolling.
                              If the Magnaflow's are the cheapest option, I may give that CRC stuff a try first...cringe :oops:
                              Edit:
                              I'm usually not so cheap...
                              Autos:
                              Plus more...
