2 fuels pumps - tre 340 idea/help
  • chappys4life
    • Aug 2011
    • 132
    I have been looking at replacing my fuel pumps (my 87 325e has 2) as they have been having some issues and am looking at the tre 340 swap. Is there anyway I can swap the tre 340 in the tank and get rid of the pump under the car that is inline? Or is there another way to get to one pump? I really hate there is 2 on mine.
    • 34839
    if you value performance, a two pump system is actually better. but you'd want the stronger pump on the outside, then the in-tank pump is just a lift pump.
    although it's an eta, so maybe it doesn't matter. still, I don't see a point in going through the hassle - better to just replace the pumps with their equivalents and leave it alone.
    • chappys4life
      • Aug 2011
      • 132
      Yeah after looking at posts and reading more just think I am going to replace both pumps getting an airtex in tank and bosch underneath.
      • dnguyen1963
        • Nov 2011
        • 2649
        Don't buy Airtex pump. I had one went out on me after six month. Tre340 or bosch is better.
        • TobyB
          • 5264
          The harder part, I found, was finding an inexpensive lift pump. There are lots of
          high- pressure pumps out there, but the low- pressure high volume supply pump
          isn't as easy to source cheaply.
          I went with the in- tank high pressure version, as it's fewer parts to fuss with.
          t
            • 34839
            you could use just about anything for a lift pump. it won't hurt if it's high pressure, except it'll draw more power than a plain lift pump. it will make the second fuel pump have to work less hard.
