Impossible to get Odometer working
  • mrgraphics
    • 221
    I have tried everything to get my odometer working. This is the last thing that doesn't work on the car. What I've done:
    1) Replaced batteries in original SI board and replaced gears
    2) Swapped out speedometer with another speedometer and gears
    3) Swapped out SI board with newer / lithium board (new batteries)
    4) Replaced entire cluster (with working SI board and gears)
    Everything on the cluster works in all these scenarios . . . it just doesn't count the mileage. Is there something I'm missing? I even replaced the sensor on the differential, but if that wasn't working the speedometer wouldn't work, right?
    Thoughts? I'm stumped.
  • reelizmpro
    • 9558
    Hmmm In each case is the speedo working? if the speedo works then it's getting a signal and should also count the mileage unless the gears are broken or the motor is bad. Are you swapping in known good speedos/clusters?
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • mrgraphics
      • 221
      In all cases everything in the cluster works. Now, whether the actual odometer motor in the speedo itself was previously good, I don't know. These are all scrapyard parts. But I've grabbed three different speedos - what's the odds that they are all bad?
      • Ayman
        • Apr 2011
        • 4190
        pretty great lol
        Originally posted by yert315
        Your mother is plug n play
        • FLG
          • Sep 2011
          • 3165
          Originally posted by howdyhoayman
          pretty great lol
          I second that. Gears are crap on these cars. Pick up a set from the garagistic guys
          Sent from my Galaxy Nexus using Tapatalk 2
          -Build http://www.r3vlimited.com/board/showthread.php?t=295277
          • idanity
            • Jun 2006
            • 775
            test a cluster in another e30 for free....
            go to a meet or something, offer up a free beer to allow someone to try yours.
            i would donate my red sedan for testing purposes..as its a stripped out drift car.
            3 pedal club
            200,k+ club
            cabrio club
            port-matched- polished- purring www.BMWpark.org
            </div>
            linux since 1999
            • cabriodster87
              • Jan 2011
              • 1042
              I've two functional speedos W/o odo movement.
              Reich und Roll!
              • agent
                Vice Grand Pubaa
                • 7960
                I have three clusters, zero had working odometers. I just put my original cluster back in after installing the Garagistic (Moto) kit and it's working great.
                Originally posted by kronus
                  • 34844
                  the SI board has nothing to do with the speedo or odometer
                  • mrgraphics
                    • 221
                    FLG - I have new gears. I transfer them each time to the "new" speedo when I try it.
                    I'd really like to get one that works, because as the years go by I'll get progressively more paranoid about how much life is left in the timing belt without some mileage reference.
                    Does anyone know of a way to test the odometer - In other words, how to apply voltage to the odometer motor when I'm in the junkyard to see if it works before purchase?
                    • agent
                      Vice Grand Pubaa
                      • 7960
                      Does your radio work? Have you checked fuse #12?
                      • mrgraphics
                        • 221
                        Yup - Everything works - all electrical. Everything but the odometer.
                          • 34844
                          same cluster housing/motherboard? I'd suspect a cracked solder joint or some corrosion issue. the function of the odometer is completely contained within the speedo.
                          • scottinAZ
                            • Dec 2009
                            • 1312
                            check to make sure that your stepper motor is running freely. the small 10 tooth gear attaches to this shaft. if it is not free, your odometer will either work slowly or not at all. otherwise check the thread on motometer speedometer calibration, and it will show you how to bench test a speedo. not something that can be done in a junkyard, but you would be able to get it functioning at your workbench.
                            I saved 15% on my Bimmer parts by switching to ...
                            • mrgraphics
                              • 221
                              scottinAZ - I'll look into that. Looks like I need to do some benchwork instead of simple swaps.
                              nando - Yes, I replaced the entire cluster on the last pass.
