Impossible to get Odometer working
  • dogsbark26
    • Nov 2008
    • 533
    Check your installation of those odo gears. It sounds like your doing it wrong. Repeatedly.
      • 34844
      yeah, either you're installing the gears wrong, or every cluster you've tried is broken. because the odometer is entirely contained within the speedometer, the car can't cause it unless the speedo isn't working either.
      • BlackbirdM3
        • 2772
        I've got a similar issue, however I just replaced the gears for the odometer, and spinning the small gear by hand, the odometer works, however, the odometer doesn't work in the car. Speedo is fine and within about 2 mph as far as accuracy.
        I'm guessing something died in the odometer motor, is there a way to replace that? I have a known good VDO motor, but I don't know if it can be swapped into a Motometer setup.
        Will
        '88 BMW M3
        • BDSax
          Junkyard King
          • Mar 2006
          • 3594
          Mt tach didn't work and it ended up being the gauge itself. Maybe the motor sent bad.
          • Gregs///M
            • Mar 2012
            • 2459
            Most odometer issues, with new gears, is poor installation. Even I've had to redo installations of gears that I've installed myself. However, I have a test bench setup so I can test only the odometer on my work bench. That way I know it is working for several miles before re-installing into the cluster.
            If your speedometer works and your odometer does not, its the gears.
            The odometer accepts a 12 volt power source and a 5V square wave signal to generate movement of the speedo/odometer.
            Owner - Bavarian Restoration
            BMW and European Electronics Repair and Restoration
            www.BavRest.com
            My Feedback Thread
            Our Facebook!
            Follow our Instagram!
            • mrgraphics
              • 221
              I finally found one that worked. I documented it in another thread. Each time I tried a speedometer I used the same gears installed the same way (so I wasn't doing it wrong.) The speedometer that did work looked different than all the others: it had a circuit board that clipped to the side of the gear protection cover. So it looked like it was a much more robust circuit construction than the other VDOs.
              • BlackbirdM3
                • 2772
                The gear mesh is spot on perfect. Everything moves smoothly. Nothing works in the car however. It works if I use my finger to turn the small gear, but it doesn't do a thing in the car. The speedo works great, but the odometer hasn't moved at all since I installed it.
                Will
                '88 BMW M3
                • Todd Black 88
                  • Oct 2007
                  • 3449
                  Not always true. My odometer did not work after new gears, and it ended up being the stepper motor.
                  Originally posted by codyep3
                  I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
                  2001 silver/Blk 325 cabby. SOLD
                  2002 325xit Sil/blk. SOLD
                  2010 F650gs twin
                  • Gregs///M
                    • Mar 2012
                    • 2459
                    That is true, the stepper motor itself can fail but is much more unlikely. However, the motor can be tested by running the odometer free of gears. It will need to be run on a work bench tho.
                    www.BavRest.com
                    My Feedback Thread
                    Our Facebook!
                    • BlackbirdM3
                      • 2772
                      My odometer showed signs of life this morning on my drive to work. It measured 1.7 miles in a 5 mile drive. Still, its more than its read since I put the thing in. I pulled the cluster last night and checked everything looking for a bad connection/solder joint, found nothing. I pulled the cover for the stepper motor and spun the motor by hand and the trip meter advanced nicely as it should. Still, the thing doesn't work. I wish I could figure this thing out.
                      Will
                      '88 BMW M3
                      • Luke_M
                        • Aug 2011
                        • 275
                        My odometer only works when I'm taking a turn really hard. It'll register a tenth or three after that and then quit. How about that one? :) I suspect the gears have been installed wrong. I just haven't taken the time to check it out.
                        Euro S50 Daily Driver: http://www.r3vlimited.com/board/showthread.php?t=279195
                        • oliver.r
                          • Mar 2012
                          • 3839
                          this guy knows everything there is to know about clusters
                          • BlackbirdM3
                            • 2772
                            I'm really curious what is up with my odometer, it showed signs of life on my way to work yesterday, nothing for the rest of the day. This morning it worked for 4.3 miles on my way to work, nothing on the way home? Its like the magnetic field that is formed between the inner and outer part of the motor is intermittent, or for some reason the outer part isn't willing to spin (I checked with the gears out, it spins freely.) I also checked with motor cover in place, still spins freely with no drag from contact with something.
                            Will
                            '88 BMW M3
                            • Cynical 1
                              • Nov 2012
                              • 129
                              i had this issue with a motometer brand in my car. replaced gears and it worked great for about 1,000 miles, then worked about 13 miles or less each day and would stop.
                              replaced it with a VDO that also had replaced gears, and works great now.
                              my thought is perhaps the 4 gears in the motometer had one slipping or jamming up... i noticed this in the VDO when i installed them - one slipped on the shaft. a drop of glue solved this.
                              maybe worth some investigation?
                              1988 325 "super ETA" - Hilde - M52B28 swapped...
                              1969 2002 - Griselda - 20VT AWP swap and full resto in progress...
                              project blog - http://www.cynicalmotorsport.blogspot.com/
                              • ForcedFirebird
                                • Feb 2007
                                • 8300
                                How are you guys pulling the brass sleeve off the e1 gear shaft? It's very easy to break the motor when pulling the brass to go with the plastic-hub gear.
                                john@m20guru.com
                                Links:
