Washer nozzles wont spray
  • noid
    • 1537
    The tank has liquid, the pump works, however neither of the nozzles will spray (not even a little). So I took a look and found that all of the spray was coming out of the T fitting.
    The question is: is it spraying out because the T fitting is faulty or because there is back pressure from clogged nozzles or otherwise?
    Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
    Your resource to tools and tips: www.rtstools.com
  • Gregs///M
    • Mar 2012
    • 2459
    T fitting needs to be replaced. But im sure your nozzles need to be cleaned or replaced. Back flush your nozzles with pressurized water or high pressure air.
    Owner - Bavarian Restoration
    BMW and European Electronics Repair and Restoration
    www.BavRest.com
    My Feedback Thread
    Our Facebook!
    Follow our Instagram!
    • bernzpeed
      • 3917
      Soak them in CLR for a few and then it will clear the nozzle out.
      89 E30 S52
      Transaction Feedback.
