Tach stuck
  • eLKuRLy
    • Oct 2007
    • 360
    Originally posted by Spyke
    OP your video is EXACTLY how my tach behaves, only it's stuck at 2k. ^Greg here has already done my SI board, and no improvement. I'm going to try looking for that ground and cleaning it off...
    ***Edit: Cleaned that ground, no change.
    that sucks! I have not had a chance to changed my si board or touched the ground connection.
    • jeffnhiscars
      • Jun 2011
      • 6011
      Originally posted by Gregs///M
      For those who messed with their cluster, check the coding plug. Its job is to interpret signal from the DME and translate into something the tach can display.
      First check the pins inside the coding plug to make sure they are not bent or misaligned. Second, try swapping with another coding plug.
      I have a spare cluster and the coding plug is date stamped and has a PN. How do you tell which one goes in what cluster or car ?
      Alice the Time Capsule
      • Gregs///M
        • Mar 2012
        • 2459
        Look up those part numbers in a site like Realoem.com
        Owner - Bavarian Restoration
        BMW and European Electronics Repair and Restoration
        www.BavRest.com
        My Feedback Thread
        Our Facebook!
        Follow our Instagram!
