Operating temp in fahrenheght
  • e30Villain
    • Jun 2012
    • 540
    Feel much better now. i was thinking of swapping out my thermostat to a 71 degree one, but seeing that winter is coming i think ill just keep the 80.
    87 ETA | Hibernating
      • 34844
      There's no reason to swap in the cold thermostat. like I said, if you are overheating, there's a problem with the cooling system. A 70c thermostat won't ultimately prevent you from overheating, but it will make the engine run less efficiently.
      • e30Villain
        • Jun 2012
        • 540
        It doesn't over heat any more. It used to but I found/fixed the problem.
        • dnguyen1963
          • Nov 2011
          • 2651
          Look...for the benefit of all, please tell us what you found/fixed.
          • e30Villain
            • Jun 2012
            • 540
            My bad didn't mean to do that.
            Thermostat was stuck closed and I had a shitty waterpump.
              Right! all the thermostat does is to set the initial maximum temperature of the engine. If more heat is being produced than the cooling system can shed the engine will run hotter than the thermostat setting.
              On the race car it doesn't matter what thermostat I have in the car in summer temps. The engine will reach and stabilize at 185-195F when on track.
              • jeffnhiscars
                • Jun 2011
                • 6011
                Stock M20 tstat is 80c which is 176f.
                Alice the Time Capsule
                • u3b3rg33k
                  • Jan 2010
                  • 2452
                  You mean minimum?
                  Ich gehöre nicht zur Baader-Meinhof Gruppe
                  Originally posted by Top Gear
                  Just imagine waking up and remembering you're Mexican.
                  Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
                  • Beije
                    • 17
                    so if I'm using a stock m20b25 engine here in the Pacific NW (Oregon), an 80c thermostat should be most efficient?
                    • e30Villain
                      • Jun 2012
                      • 540
                      Yeah, you should already have an 80.
                      • u3b3rg33k
                        • Jan 2010
                        • 2452
                        most efficient would be the hottest one. is there an 88C?
                        • e30Villain
                          • Jun 2012
                          • 540
                          I think 80 is the hottest it goes.
                          • u3b3rg33k
                            • Jan 2010
                            • 2452
                            I must be thinking of the aux fan thermo-switch then.
                              • 34844
                              there's an 88c thermostat for the M42, don't know if it fits in the M20 though.
