Modify windows so they go all they way down?
  • Herr Faust Schinken
    • Feb 2012
    • 3580
    Originally posted by asdfg68plus1
    Are they interchangeable?? and I thought 88+ was a late model, and I have an 88...
    so do i , i have early regulators so you do too
    88 325is Five Speed
    Lachssilber
    • einstein57
      • Jun 2007
      • 10780
      Originally posted by Todd Black 88
      Iirc the early cars use a different regulator that doesn't allow the windows to completely go in the doors. The late models use a different regulator that allows them to sink completely in the doors.
      That's the way it is on my cars. M3 doesn't go in all the way, cabby does.
      I dunno
      Do verts and coupes even use the same glass and regulator?
      IIRC my windows go all the way down
      www.gecoils.com
      • oldmann
        • 265
        This is an easy one, Remove the door panel, lower the window all the
        way, look for the plastic block that stops the window at the bottom,
        remove the block and remove as much material as you need to get the
        window down all the way, don't remove too much at a time.
        Got tired of the dent in my elbow/arm and dug into it, not a difficult task.
        91 318i by the way.
        • slippery
          • Nov 2011
          • 378
          Will be trying this next weekend. Thanks for the tip,
          J
          • vpilarrt
            • Jun 2006
            • 2096
            If its a late model be aware that the plastic block is on the back side of the drive mechanism. Its held on by a bolt that is visible on the front side in a slotted hole but the slot doesn't give you enough adjustment to allow the window to go down far enough. Do not remove so much material that the top edge of the window goes below the seal on the door.
              • 34844
              my late model windows go all the way down?
              • kamotors
                • Nov 2007
                • 7102
                my late model windows go all the way down as well. but in my friends 85 and 88 E they dont go below the black trim piece and they cut into your arm.
                7speedshop.com
