Sumbitch ICV tube
  • MoreMayhem
    • Feb 2012
    • 650
    Sumbitch ICV tube
    So I've now replaced this little bitch for the third time in 18 months:
    There must be what, 6 or 7 other people who use this forum that still have a stock M20 engine in their E30. For those people, and the others who remember the days when they ran a M20 engine: did your ICV tube split like this a couple times a year? Is there another, better way to attach it? Hose clamp perhaps?
    Does someone make a better version of this that doesn't split right away?
  • Swanny
    • Mar 2012
    • 2834
    Can use silicone tubing like the kits on ebay
    Swanny!
    SUCKERS.
    • 5Toes
      • 9836
      Mine was fine...?
        • 34839
        how is the mount on your airbox/afm?
        • K1CKBAC
          • 306
          Buy OEM.
          My expectation is an immediate 5 speed swap. Autos suck more than a 50 year old whore.
          • MoreMayhem
            • Feb 2012
            • 650
            I've seen those silicone tubing kits on ebay and other sites. That may be the route to take. Being the cheap-ass that I am, I wonder if I can buy just the one tube and not every tube under the hood.
            The mount seemed okay, no unusual rough edges that would start the tube to split. Is that what you mean?
            • bmw325csi
              • May 2007
              • 4045
              This has never happened to any of my m20 cars. Never.
              harry/harout
              • MoreMayhem
                • Feb 2012
                • 650
                Originally posted by K1CKBAC
                Buy OEM.
                LOL, each one has a BMW emblem molded into it.
                Now whenever I go to the parts counter at the local BMW dealer, he always says, "need an ICV hose with that?"
                • bmwguy325is
                  • May 2011
                  • 1263
                  Yes this.
                  How ever I secured mine with zipties. Cheaper and smaller than hose clamps.
                  sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
                  The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
                  • EatsHondas
                    • Sep 2012
                    • 404
                    I recently bought my car and the hose (definitely not recently replaced) seems fine. The surface has a few hairline cracks, but no hissing noises or splitting. I'm not gonna replace it until it becomes a problem.
                    1989 325i Lachssilber Sedan
                    5-Speed Swapped
                    M30B35 Swapped
                    MegaSquirt MS3X
                    1987 325i Lachssilber Sedan
                    260k OEM Automatic Daily Baby
                    • Court M3
                      • Jan 2004
                      • 6713
                      Hose clamp is what I used on mine.
                      Continuous For Sale Thread
                      323i s50
                      • e30trooper
                        • 11576
                        ive never seen one split. best to use a hose clamp next time.
                        • MoreMayhem
                          • Feb 2012
                          • 650
                          Thanks for all the replies. I'll put a hose clamp on the new one.
                            The hose splits because of the angle it takes. A hose clamp, or even a zip tie, will prevent it from splitting.
                              • 34839
                              they didn't come with hose clamps, and they don't tend to split like that all the time. I think that is a band-aid, something else is the root cause.
                              I asked about the support that holds the airbox to the car, the one that the cruise control bolts to. if it's broken, missing, or you have an aftermarket intake with no support, then the ICV and intake boot end up holding up your air filter/AFM, which would make the tube split (and even the boot will begin to tear).
                              also what about motor mounts? if they are old/broken, the engine will move a lot more. the airbox is fixed to the car, and all the movement is taken up by the intake boot and that rubber tube.
                              actually that makes me think that's why they went with the T style ICV for the latest builds, the intake boot is a little more flexible, maybe it takes some strain off the ICV tube. But it still shouldn't fail that easily, especially if they are new tubes.
