Driver Side Power Window is not going down on 92 325iC
  • Prost
    • Nov 2012
    • 193
    I got the car yesterday and notice that the front driver side power window cannot go down, it will go down for an 8th of and inch after some push but is a no go afterward, when I push the "up" button, it will move that 8th an inch up instantly...I know there is power and "head" the motor is trying, but I have no luck after several try...any help from the expert?
    All other three go ups and down with no problem, except the passenger front going slowly in the middle of moving up...
    92 Alpine White 325iC M-Tech II Appearance Package
  • bowtie2bimmer
    • 830
    Have you tried slamming the door shut really hard?
    Seriously, it has worked more than once for me
    1987 BMW 325ic - Emma
    • dnguyen1963
      • Nov 2011
      • 2649
      sounds like you need to open up and lube the window mechanism.
      • Prost
        • Nov 2012
        • 193
        I was thinking about that too...should head to autostore to get some lube...I don't think WD40 will fit this application :p
        • Cletonius
          • 2809
          open up and clean the switch too. I had a problem where I couldn't roll my window up sometimes. When I took the switch apart it was all nasty in there. A few minutes with contact cleaner and an emery board and it works like new.
          - Josh
          1990 325is
          Need a shift boot?
          Looking to buy shift boot frames, PM if you have one to sell
          Here's what happens when you let the internet pick your license plate
          • dnguyen1963
            • Nov 2011
            • 2649
            No, do not use WD-40. Buy a proper grease like this...
            http://www.autozone.com/autozone/acc...ier=54185_0_0_
            • Prost
              • Nov 2012
              • 193
              Thanks...I am just joking :p
              • jeffnhiscars
                • Jun 2011
                • 6011
                If it moves at all its more likely to be the switch so start by swapping it with one that works to confirm. Then do as suggested above.
                Alice the Time Capsule
                • Todd Black 88
                  • Oct 2007
                  • 3449
                  Swap the passenger switch to the drivers side and try again.
                  Originally posted by codyep3
                  I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
                  2001 silver/Blk 325 cabby. SOLD
                  2002 325xit Sil/blk. SOLD
                  2010 F650gs twin
