Grease and crap
  • rodsfromday
    • Jul 2012
    • 35
    Grease and crap
    When I removed valve cover this is what I found. This is on my E46.
    It's a lot of old grease and crap. Is that normal? What's the best way to clean it all up.
    Thanx.
    Sent from my GT-I9300 using Tapatalk 2
    That is a sign of too long an interval between oil/filter changes for the usual driving conditions (probably mostly urban cycles). A series of additions of a flush compound, driving a hundred miles or so and an oil/filter change should get a lot of it out.
    I presume the oil has been being changed at the factory intervals (15-18k). Reduce that interval to no more than 7.5k and try to get the car on the highway at least once a week for 30 minutes.
    • McGyver
      • 4636
      that is absolutely disgusting! i would pour some stuff into the oil that is designed to thin and remove gunk, drive it for a few minutes, then drain EVERYTHING out and refill with oil. if it were my car i would probably do that again in a couple hundred miles and then stick to 3.5k intervals for standard oil and 7k for synthetic.
      good luck!
      • toointoxicated60
        • Sep 2009
        • 355
        holy crap. that is scary looking.
        You need to do more frequent oil changes.
        • bmwguy325is
          • May 2011
          • 1263
          Ya thats some engine abuse for sure
          sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
          The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
          • Todd Black 88
            • Oct 2007
            • 3449
            Typical e46 oil change interval issue there. My wife's car was exactly the same.
            I used a rubber spatula and scraped all I could out before doing an oil change every thousand kilometers with a flush compound, for 5 thousand kilometers.
            Originally posted by codyep3
            I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
            2001 silver/Blk 325 cabby. SOLD
            2002 325xit Sil/blk. SOLD
            2010 F650gs twin
            • Simon S
              • Oct 2004
              • 3758
              whoa.. both cool and scary looking..
              -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
              • TobyB
                • 5297
                You got sludge.
                Be careful if you decide to touch it- globs can plug up things.
                Especially lifter orifices...
                More long trips, more frequent changes.
                t
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  Automatic transmission fluid is a good cleaner for this sort of thing. Add a quart of it to the oil (subtracting 1 quart of oil from the total) and run it for a week or two, then change the oil again. May want to do this a few times considering how bad it is. But some cheap oil to do the flush, makes things a lot more cost effective. Running cheap oil for a short period of time won't hurt anything.
                    I agrees with everything except the use of cheap oil (and filter). The ATF is going to affect the oil's lubricating properties, so you want the right oil (and filter) in the engine to minimize the wear.
                    • AndrewBird
                      The Mad Scientist
                      • 11898
                      While I do agree a bit, the short amount of time the oil will be in the engine is not going to do anything. As long as you use the correct weight oil, a cheaper brand like Pennzoil or even your auto parts store brand will lubricate well enough. I mean, we are only talking a few hundred miles, not thousands.
