My fuel gauge needle is moving erratically, and it is annoying as hell. If I tap on the plastic cover for the cluster, it will make it wobble more, and occasionally "stick" where it actually belongs relative to where the fuel level is. Is there a ground nut or something that is loose?
I also have the "smack the dash / cluster housing to get the backlight working" issue, although that has been there forever. Is that also an easy fix?
Thanks!
Thanks!
