grease, mystery hose
  • ///M42 sport
    • 3952
    whats going on here? looks like grease is coming out of this hose? lulz
  • jclar
    • 265
    That's the parking brake cable isn't it? And maybe just grease that was used to keep it from seizing up when they were replaced?
    '86 325es M50
    • ///M42 sport
      • 3952
      parking brake cable? yea prob. Didnt know it was packed with grease. Seems like its losing grease though...theres alot of it
      • Dj Buttchug
        • Jun 2010
        • 7681
        the ebrake cable is not packed with grease, however the cv axle boot is...
        Turbo M42 Build Thread :Here
        Ig:ryno_pzk
        I like the tuna here.
        Originally posted by lambo
        • ///M42 sport
          • 3952
          anymore ideas? where the grease is from?
          • TobyB
            • 5280
            rear wheel bearing, if the CV is OK.
            t
            • ///M42 sport
              • 3952
              so thats the parking brake cable for sure?
              • Dj Buttchug
                • Jun 2010
                • 7681
                yes.
                heres my guess. okay you see the fluid dripping down the backside of the brake rotor shield. That leads me to believe that the axle shaft/ bearing is shot. However you do have what seems to be brake fluid close to the brake line inlet on the caliper...? this fluid on the rotor shield could be brake fluid? someone did a messy brake line install?? the brake line looks new. thats the only reason why I assume
                Ig:ryno_pzk
                • ///M42 sport
                  • 3952
                  yea good detective skills. I was replacing my brake lines in this pic and thats brake fluid you see.
                  The grease is a seperate issue...I dont have any whining from rear...this is just something I happen to see while my car was up on the lift.
                  • Dj Buttchug
                    • Jun 2010
                    • 7681
                    I would clean it all up and call it good then. thats probably just road grime/ dirt and grease from being 20 some years old.
                    Ig:ryno_pzk
                    • AndrewBird
                      The Mad Scientist
                      • 11898
                      Clean it up, drive it for a few weeks and check it again. If there is more grease, then you have a problem. As others have said, it's likely a ripped CV boot or a bad wheel bearing (or both). Even though you don't hear any noise from the bearing, doesn't mean it isn't starting to fail. Have they ever been replaced?
                      • 603Racing
                        • Dec 2010
                        • 612
                        With a ripped CV boot you will usually see a circumference of grease splattered in a line even with the rip in the boot.
                        90 325i DD/Track
                        03 Durango 5.9
                        Originally posted by e30mpg
                        It is recommended to get new gasket but this is R3v and we just copper spray that shit......slap biotch on and tighten to tq.
                        • ///M42 sport
                          • 3952
                          yup both the half shafts have been replaced, along with the rear wheel bearings.
                          • CHIF8008
                            • 3447
                            grease from the previous cv joint?
                            -FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
                            -The Beauty in the Tragedy-
                            MECHANIC SMASH!!- (you all know you do it)
                            Got Drop?? ;-)
                            But of course
                            E30s are know to be notoriously really really really ridiculously good looking
