Removing the engine fan, WONT BREAK FREE!
  • Maximum_E30
    • Feb 2013
    • 56
    any ideas?
  • Gregs///M
    • Mar 2012
    • 2459
    Its reverse thread, must loosen it by turning clockwise.
    Owner - Bavarian Restoration
    BMW and European Electronics Repair and Restoration
    www.BavRest.com
    My Feedback Thread
    Our Facebook!
    Follow our Instagram!
    • Maximum_E30
      • Feb 2013
      • 56
      yeah, I replaced the fan and fan clutch on my zinno eta, but i cant get it loose on my m42
      • Farbin Kaiber
        Lil' Puppet
        • 29502
        Fan clutch tool, or 32mm bicycle wrench.
        • dnguyen1963
          • Nov 2011
          • 2648
          You need to use a hammer and wack on the 32mm wrench. Make sure to catch the wrench when the nut is free.
          • Cletonius
            • 2809
            Unbolt the pump while the fan is attached. Clamp the impeller in a vise and you're good.
            - Josh
            1990 325is
            Need a shift boot?
            Looking to buy shift boot frames, PM if you have one to sell
            Here's what happens when you let the internet pick your license plate
            • bmwguy325is
              • May 2011
              • 1263
              One can put a pry bar on the bolts of the water pump pulley to keep them from spinning.
              There is the mystical method of put wrench on nut and have your friend start the car...........(if you do this please you tube it)
              sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
              The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
              • Maximum_E30
                • Feb 2013
                • 56
                ^^^^^^^^wow,the mystical method sounds like a really good idea...ya know because its reverse thread and everything... lol
                • bmwman91
                  • Oct 2004
                  • 3134
                  I usually have a partner tug on the water pump belt to get it to grip the pulley, stick a large crescent wrench on the fan nut and then smack it with a dead-blow hammer. Works every time.
                  Transaction Feedback: LINK
                  • fronton
                    • Oct 2009
                    • 1262
                    unscrew one of the three bell bolts enough to get a chain link on it. secure that chain to something that won't move with no slack. use a regular adjustable wrench on the fan nut turning clockwise.
