random ass stalling
  • chuckybob
    • Aug 2004
    • 952
    random ass stalling
    my car stalls when it gets warm. the strange part is that once it begins to stall, opening the throttle lowers the idle speed. at closed throttle, it idles perfectly fine. if the car stalls completely or the ignition is turned off, it will only crank until about 10 minutes later, when it can run again. i loosened the icv adjusting screw and it seemed to prolong the stalling, but it hasnt stopped. any ideas what could be causing this?
    : : 1984 318i : : PNW E30 Crew : : Sold!!
    Now becoming the R3vlimited Pro3 car
    http://www.r3vlimited.com/board/showthread.php?t=93780
  • Digitalwave
    is a poseur
    • 6299
    Kinda sounds like a bad vacuum leak to me. Does your AFM intake boot look to be in good shape?
    RISING EDGE
    • chuckybob
      • Aug 2004
      • 952
      no vacuum hoses are leaking. idle is rock solid at 1000rpm until the engine warms up. and even then, its very consistent when its not stalling.
      • Digitalwave
        is a poseur
        • 6299
        The engine doesn't have to have a lopy idle to have a vacuum leak.
        RISING EDGE
        • bimmer8604
          • 3017
          sounds vacuum-ey.
          Are you just looking at the hoses? or actually touching, pinching, feeling, squeezing, carressing, oh woops, got a bit sexual right there.
          Do a through check, not just pop the hood and look.
          Kyle
          1988 M3, 97 840, 99 XJ
          DILLIGAF
          • asubimmer
            • 6482
            vacuum
            • lordofthewaters
              • Oct 2005
              • 714
              Get a can of wd-40 or even ether and spray it over your vaccuum hoses, if you have a leak you'll know it when you spray over it.
              Sarcasm is a body's natural defense against stupid.
              When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
              "My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson"
              Old age and treachery will always overcome youth and skill.
              • arsevader
                • May 2005
                • 1025
                My vote is for electrical. Vacum leaks are usually more pronounced when cold.
                Could be a bad trace in the AFM or a faulty TPS.
                • RobertK
                  Kicked cancer's ASS.
                  • Jun 2005
                  • 5864
                  I was going to say faulty AFM since you can reproduce the same symptoms on a good running E30 by disconnecting the AFM harness while it's running.
                  This works even better with throttle body / carb cleaner.
                  • turnofftheradio
                    • Apr 2005
                    • 448
                    I was thinking fuel pump or regulator? enough press to idle, but not enough to accelerate.
                    • AndrewBird
                      The Mad Scientist
                      • 11898
                      Sounds like it is running too lean. I.E. - Vacuum leak. Maybe your throttle body gasket or intake manifold gasket? Somewhere after the AFM.
                      Could also be the AFM like others said. Jordan was having a problem with his car at WOT where the contacts for the AFM were worn to the point of no longer making electrical contact. I'll try to find his post for you.
                      Edit: Here is the link - http://www.r3vlimited.com/board/show...&highlight=AFM
                      • chuckybob
                        • Aug 2004
                        • 952
                        ive left my afm unplugged before on accident, this is much different then that was. ill re-check it for vacuum leaks and check the afm contacts and resistance tomorrow.
                        • chuckybob
                          • Aug 2004
                          • 952
                          went over every black vaccum hose and the oil seals with the wd-40, no vacuum leaks to be found. pulled the afm to test the resistance through the flap range, it dips about halfway down, and the afm also only shows 200ohm resistance at 60 deg F (should be 2200@68F), but kencopperwheat has very similar afm test results.
                          his thread: http://www.r3vlimited.com/board/showthread.php?t=63031
                          are these normal behaviours of an m10 afm?
                          • bimmer8604
                            • 3017
                            i dont think it would be the TPS, as e30's use just a switch, either on or off.
                            you could try changing the AFM with a known good one and see if that works.
                            Kyle
                            DILLIGAF
                            • chuckybob
                              • Aug 2004
                              • 952
                              the afm traces look good and the sensor flap isnt binding at all. can someone with a known good m10 afm check the resistance and temperature values to compare?
