OBC doesn't light up
  • Ceeker
    • Sep 2009
    • 2821
    Originally posted by noid
    http://www.armchair.mb.ca/~dave/BMW/e30/
    Look at sections 7000 and 8000 in the PDF.
    thanks for all your help; I looked through the PDF but there nothing indicating WHAT I'm supposed to be looking for. I removed the lower column cover to see if there is a plug or connection. it's all spaghetti to me.
    The picture diagrams are useful but all I see on the schematic :is look for details to s213."
    when I go to look I don't see anything to shows me what I'm suppose to be searching for.
    • gkurey
      • 882
      Bump on this....having the same issue and I am super perplexed!
      • e3phonehome
        • Nov 2016
        • 13
        Bump on this, having the same issue on 87 IS
        • riskybiz86
          • Feb 2018
          • 45
          Aaaand two years after this was posted I'm having this issue as well. It's not light bar (used a new one) and not the OBC (replaced with a different one and same results).
          I may mess with it some more this weekend, but curious as to whether this was ever resolved!
          • Downeaster1
            • Mar 2008
            • 85
            Hey all, just wanted to bump this old post instead of making a new one. Also having the same symptoms. New light board doesn’t work.
            1985 325e Sedan, 1986 325e Sedan, 2006 BMW X5, 2012 M3 Sedan, 2013 135is, 2017 M3 Sedan ZCP Competition
            • moatilliatta
              • 6149
              Probably the bulb you have is not an OEM bulb as most are NLA.
              AND, aftermarket parts usually never fit proper.
              I just spent an hour diag wires to find the the 2 pins that go into the "Bulb socket" are not making it into the holes. With a little bend of the male pins inside of the OBC the finally went into the bulb socket holes and the bulb function is now working.
              I had a programma bulb, yours may vary.
              @Zakspeed_US
              • Downeaster1
                • Mar 2008
                • 85
                That's insanely helpful. I also have bought the programma set. I'll give that a shot. Thanks!
                • moatilliatta
                  • 6149
                  Keep us posted!
                  @Zakspeed_US
                  • Das Delfin
                    • Sep 2014
                    • 2293
                    I want to point out that the backlit buttons come on with the dash lights but the LCD backlights only come on with the key in the ACC or ON position
                    the bulb in the back of the OBC unit that illuminates the buttons is the same as the dash bulbs and are not NLA
                    • NeverEnough02
                      • Mar 2015
                      • 224
                      Same issue here. Anyone figure this out? What is the connector number on the on the obc? Buttons work fine. 2 light boards not lighting up.
                      • thrashandburnn
                        • Mar 2022
                        • 41
                        Having the same issue Anyone ever find out? Before taking out the OBC this morning, it was working fine, but then I took it out to replace the bulb for the buttons, and after I put it back in, it was very dim. I have power up to the green plug, and I have swapped in 2 other OBCs with the same result. Took one of the lightstips out, and tested it, and the left-side pin is barely getting any power, its almost like a capacitor is bad or something. I have no idea, and this is the only forum I have been able to find anything remotely close to my issue.
                        • khiobrien2
                          • Feb 2023
                          • 98
                          I also still have this exact issue after months of trying shit. Replaced so many things at this point… I don’t care anymore. I’ll deal with a broken obc I guess.
                          • thrashandburnn
                            • Mar 2022
                            • 41
                            I ended up figuring out what my issue was. I had a bad capacitor on the inside of the OBC. i just jumped it using a small piece of wire and some solder straight into the light bar. Works normally now, and even the dimmer works. If you really want to dig that deep into it like I did, you gotta start testing all those small electronics.
                            • cory58
                              • 1021
                              Thanks for posting what you figured out!
                              1992 325i Cabrio
                              1988 320i Touring
                              2000 M5
                              1977 530i
                              2015 328i - Euro Delivery/Performance Center Delivery
                              BMWCCA
                              E30CCA
