Random turn signal sound going off
  • TroyShark
    • Oct 2012
    • 195
    Started my car earlier today and the turn signal sound was randomly going off without the turn signals being on. When I switch the turn signals on they work fine but then after they turn off the sound is still ticking. Anyone have any ideas?
    Update: So a couple day ago turn signals just stopped working all together. The noise went away and when I turn on the signals they do not work. However the hazard lights still work. I picked up a used stalk from someone and swapped it in. It did not fix the problem. So either I am unlucky and got another broken stalk or it's a different problem. Anyone have any ideas?
  • Gregs///M
    • Mar 2012
    • 2459
    Could be a sign of a failing turn signal stalk.
    Owner - Bavarian Restoration
    BMW and European Electronics Repair and Restoration
    www.BavRest.com
    My Feedback Thread
    Our Facebook!
    Follow our Instagram!
    • TroyShark
      • Oct 2012
      • 195
      Bump
      • FLG
        • Sep 2011
        • 3165
        Is it a consistent tick like the turn signals or just random?
        -Build http://www.r3vlimited.com/board/showthread.php?t=295277
        • jeffnhiscars
          • Jun 2011
          • 6011
          The emergency flashers will also activate the flasher and that switch could possibly be stuck (as they are prone to be) so that when you hit a bump it makes contact.
          Alice the Time Capsule
          • trashycamaro
            • Feb 2011
            • 70
            I had this with a broken stalk (one of the interior switches was busted). After I replaced it the relay firing noise was gone.
            1991 e31 - Black on Black, 5.0L/6 Speed. Sold
            1990 e30 Cabriolet, 2.5L/auto. Sold
            1999 e39 Touring, 2.8L/auto. Sold
            1988 e30 Cabriolet, 2.5L/5 Speed. Going for retro modern convenience driver.
            • TroyShark
              • Oct 2012
              • 195
              So you just replaced the turn signal stalk?
              • TroyShark
                • Oct 2012
                • 195
                So a couple day ago turn signals just stopped working all together. The noise went away and when I turn on the signals they do not work. However the hazard lights still work. I picked up a used stalk from someone and swapped it in. It did not fix the problem. So either I am unlucky and got another broken stalk or it's a different problem. Anyone know?
                • goldenbb
                  • Jun 2013
                  • 208
                  Maybe the relay. Hazard relay is separate.
                  I'm chasing an annoying turn signal issue, too. The damn things go frenetic but they work. I just had the bumper off checking/cleaning all the contacts and wiring and nothing--am going to pull the wheel off and replace the relay next.
                  '90 zinno 325iS
