easiest way to disable SRS warning light?
  • UpOn3
    • Feb 2013
    • 62
    what's the easiest way to disable the flashing red SRS warning light due to the removal of the airbag steering wheel for a non airbag wheel? can I just apply a resistor (what rating?) at airbag socket or should I just pull a plug somewhere? Thanks.
  • Dj Buttchug
    • Jun 2010
    • 7680
    just take out the airbag computer system all together. its a large orange box under the steering column.
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • frankenbeemer
      • Sep 2009
      • 2260
      Install pre SRS check panel.
      Don't buy an e30
      They're stupid
      1989 325is Raged on then sold.
      1988 325 SETA 2DR Beaten to death, then parted.
      1988 325 SETA 4DR Parted.
      1990 325i Cabrio Daily'd, then stored 2 yrs ago.
        • 34844
        Remove the orange computer, or just unplug it.
        • UpOn3
          • Feb 2013
          • 62
          Thanks. Is there a specific plug or just unplug everything from the orange box?
          • Cletonius
            • 2809
            I like how you operate. I want to do that anyway
            - Josh
            1990 325is
            Need a shift boot?
            Looking to buy shift boot frames, PM if you have one to sell
            Here's what happens when you let the internet pick your license plate
            • Red46
              • 1151
              M-Tech wheel and German check panel ftw
