V12 Intake Swap?
  • RobertK
    Kicked cancer's ASS.
    • Jun 2005
    • 5864
    V12 Intake Swap?
    I've heard alot of people say that the V12 BMW engine is basically 2 M20s mated together. With that in mind I did some chart comparisons on RealOEM.com and it looks like it *might be possible.
    Any of you seasoned vets know if this has been tried before? If it is possible would there be any benefits to it?
  • mspiegle
    • 1026
    I was wondering about stuff like that too... there's gotta be SOMETHING from that motor that can work on ours and provide benefit. Jordan mentioned once that the heads on the V12 motor *may* be less efficient than the M20 motor... maybe in that case M20 heads could benefit the V12 motor... but who knows.
    Michael Spiegle
    '01 Ford Escape / Daily Driver
    '99 M3 / Track Car
    '87 325is bronzit / wtf car
    '06 Daytona Triumph 675 / Daily Rider
    • RobertK
      • Jun 2005
      • 5864
      http://www.realoem.com/bmw/showparts...49&hg=11&fg=40
      Appearently it has a flange you bolt to the head before you bolt the intake on. So you would probably need both.
      • 2002maniac
        • 4260
        go for it. It would at least look cool.
        • RobertK
          • Jun 2005
          • 5864
          I've started working on finding a price for the intake manifold and flange off a 750i parts car I found online. I'll let you know more when the guy gets back.
          If the price is right I'll buy it and try it.
          • chuckybob
            • Aug 2004
            • 952
            ritalin kid, youre my swap-mod hero.
            : : 1984 318i : : PNW E30 Crew : : Sold!!
            Now becoming the R3vlimited Pro3 car
            http://www.r3vlimited.com/board/showthread.php?t=93780
            • rs4pro3
              • 5808
              it would even work, you'd need the p-side manifold(or the one that bolted to the passenger side head). I'm pretty sure though you'll run into interference issues with the brake booster. The M20 manifold is C shaped where as the v12 is almost straight with a little upward bend.
              85 325e 2.7 ITB'd stroker
              • rs4pro3
                • 5808
                I would first buy just 1 of the 2 gaskets and see if the bolt pattern and ports line up first.
                • RobertK
                  • Jun 2005
                  • 5864
                  I don't think it would be to terribly bad. I was thinking more along the lines of using the driver's side intake manifold.
                  Anyone on the boards have a V12 7 or 8 Series that can do some measuring?
                  I plan on getting my car dyno'd as it is in stock form now before I actually start doing any performance type mods. That way, if the V12 intake mod does work, I can alteast find out if it's worth the trouble.
                  Another thing to consider this that since the V12 intake is kind of like a log intake it make be even better for those looking to use FI.
                  • rs4pro3
                    • 5808
                    I believe the flange rotation is wrong on the driver's side intake manifold. Remember on the v12 the intake side is on the inner side of each head, so the head most like our m20's is the passenger side head.
                    • rs4pro3
                      • 5808
                      Here is a picture of the Passenger side head's intake
                      If you notice the ports and mounting is completly different then the m20's
                      Plus you'll have the oil drain from the head to deal with that the V12 dosn't use.
                      • RobertK
                        • Jun 2005
                        • 5864
                        Of course there is a flange that goes between the head and the intake manifold. If the driver's side intake goes to the passenger with the flange angled upwards then would you not still use the driver's side intake and flange?
                        Nice Pics BTW.. do you have any of the flange?
                        • rs4pro3
                          • 5808
                          That site has some good pics of the intakes and how to replace the gaskets.
                          • rs4pro3
                            • 5808
                            the rotation on the last 2 cylinder is the oposite direction, or else possible the v12 intake could bolt right to the head without the gasket plate.
                            • rs4pro3
                              • 5808
                              few more pics
                              Supprisiling v12 rebuilds have actualy been pretty well documented on the internet.
