Diff noise or drive shaft noise?
  • FireFight
    • Mar 2012
    • 1367
    I'm trying to trouble shoot this grinding/whining/"wha-wha-wha-wha" sound coming from under my 318i, it's clearly drive train because it only makes it when the car is moving.
    During acceleration it more of a "wha-wha-wha-wha" sound like the drive shaft is out if balance, but when I let off the throttle/toss is out of gear/put in the clutch the grinding whining sounds starts and slowly goes away until I come to a spot.
    Any way I can rule one rule one out that I'm not thinking of?
    WTB:m60b40 in PNW
    Zachary Ripley
    85 318i M50B25tu.
    92 525it 5 speed.
    80 244gl (m60 prepping).
  • TobyB
    • 5297
    Center bearing?
    t
    • FireFight
      • Mar 2012
      • 1367
      Just replaced
      As well as the diff fluid, which I didn't see any metal shards in there.
      No change in noise level
      WTB:m60b40 in PNW
      Zachary Ripley
      85 318i M50B25tu.
      92 525it 5 speed.
      • redlightpete
        • Mar 2012
        • 266
        Maybe put it on jackstands and have a listen.
        • jeffnhiscars
          • Jun 2011
          • 6011
          Im guessing drive shaft. You could have installed it out 180 degrees, you may not have properly preloaded the CSB causing premature failure (depends on how long ago), you could have a bad ujoint or all of the above
          Alice the Time Capsule
          • FireFight
            • Mar 2012
            • 1367
            I'm getting a new-to-me drive shaft today to see if that solves my issues.
            I'm hoping so, its pretty annoying to have people stare at my POS because the sound not the ugly factor
            WTB:m60b40 in PNW
            Zachary Ripley
            85 318i M50B25tu.
            92 525it 5 speed.
