what is this? (random fuse block
  • Coupelx
    • Oct 2013
    • 169
    has 2 wires that come out of the harness under the fuse block hooked to one end of each fuse but nothing on the other side. A previous owner made a halfassed attempt to fix the wires at some point so I'm considering removing it. It has a little plastic cover that says Germany on it so it appears factory but I can't find a reference to it anywhere. Car is an 86 325e.
  • McGyver
    • 4636
    looks like the auxiliary fuse box. it should have a wire going to it for constant 12v and a wire for switched 12v. It's basically just used for aftermarket accessories.
    • TobyB
      • 5296
      Looks like it's off a Benz, tho!
      heh.
      t
      • Coupelx
        • Oct 2013
        • 169
        Ok cool. I think I'll relocate it to my tub of BMW stuff for now and heat shrink off the wires that have been crimped together and sealed with bathtub caulk. :/
        • Vincent Brick
          • Feb 2013
          • 879
          Holy shit that is amazing. Every car should come with that hidden somewhere. BMW or Benz, I'd like to shake the hands of the engineer who put it there and the bean counter that let it remain.
          1991 325i Sport - Calypsorot Metallic - DAILY DRIVEN
          WTB in SoCal: 8"/10" Lukebox, leather Sport steering wheel, 60L MotoMeter fuel gauge, Thule/Yakima roof rack
          • McGyver
            • 4636
            I guess his has the same fuses as the e28, but my '89 and '91 both have the newer fuse style.
            why touch it if everything works? you'll need to double check that nothing has been wired to it over the years.
            • Coupelx
              • Oct 2013
              • 169
              there is nothing hooked to it and a previous owner had spliced the wires with connectors that were way too big and then sealed them with what appeared to be latex caulk. this was also done to what was left of the brake sensor wires. Wires for the fuse block were trimmed back to the first splice and covered in heat shrink then tucked away for potential future use. I drive this car about 600 miles a week currently so ANYTHING i think could become an issue is dealt with.
