Cam choice
  • digger
    • Nov 2005
    • 6198
    Cam choice
    I am going to get a shrick cam for an M20 that i'm going to build for a 325is. It will be atleast 2.8L and may be even a IE stroker kit. Knowing this what cam should i get.
    272/272 or 284/272 or 288/288 or 304/304
    i don't want an all out racer so a 304 or 288 are probably not needed. I want it to be able to be used as a daily driver with good low down torque charactersitics so it comes down to the 272/272 or the 284/272.
    Which should it be? What will be the difference between the 272/272 and 284/272 in terms of drievability and performance?
    Cheers
  • 88325isboy
    • Mar 2004
    • 1058
    Same here i am thinking about getting the 284. Anyone running the 284?
    '87 325 (Track Rat)
    '04 C5500 Wrecker (Work)
    '94 525i (Daily)
    '90 325i (R.I.P)
    H&R Race, Racing Dynamics Sway Bars, Tree House CAB's, Sparco Strut Bars and more.
      • 34844
      the 284/272 is perfect for the street IMO. I don't think I would have been happy with just a 272/272. my driveability and idle were barely affected at all, it lopes but there's plenty of bottom end torque and it screams up top.
      • MrK
        • Jan 2006
        • 709
        Speaking as a 304/304 owner, I'd have to say that the idle is quite annoyying, and probably would still be a little annoyying at 288/288.
        So I vote 284. So that at least you feel a good power increase, while retaining streetability.
        This is your M20 on steroids:
        • digger
          • Nov 2005
          • 6198
          are there any before and after dyno plots of cam upgrades floating around?
          • 88325isboy
            • Mar 2004
            • 1058
            So with the 284 i should get the valve springs too or will the stock ones hold up?
            '87 325 (Track Rat)
            '94 525i (Daily)
            '90 325i (R.I.P)
