Car cranking, but not starting(Now with spark!)
  • ST1G
    • Oct 2012
    • 6689
    #61
    He got his info from Claus Luthe himself. But really, if there were ONE person in the e30 world I could listen to for advice, he is who I'd pick.
    So what you're saying is I should follow that to a T and see what I find?
    • Farbin Kaiber
      Lil' Puppet
      • 29502
      #62
      Yep. He is on here too, after going through that, shoot him a PM, same username here as there.
      • ST1G
        • Oct 2012
        • 6689
        #63
        I just realized that I've seen him before. Same with over on BF.com he seems to always be right.
        • Farbin Kaiber
          Lil' Puppet
          • 29502
          #64
          Originally posted by ST1G
          I just realized that I've seen him before. Same with over on BF.com he seems to ALWAYS be right.
          ftfy.
          • ST1G
            • Oct 2012
            • 6689
            #65
            Srsly though.
            • ST1G
              • Oct 2012
              • 6689
              #66
              Okay, so I went through the tests in post 4 from Jlevie and this is my results. All tests were with a Fluke multi meter. Battery gives me 12.4V when I measure across it.
              1) Disconnect the coil negative and check continuity from that connector to
              DME pin 1. Also verify that from DME pin 1 to ground is an open circuit.
              I have this.
              2) Check the resistance across DME 47 & 48, which should be 500-560
              ohms. If the CPS is dismounted, the resistance can be seen to change
              from about 500 to 540-540 when a ferrous object is brought to the face of the
              sensor. Neither pin should be grounded.
              With the CPS plugged in I have 507Ω. It seems I should have 550Ω with the resistance of the CPS added in I think. When I unplug the CPS I get infinite resistance at the pins.
              No grounding on either pin.
              Curiously enough I don't get continuity beeping from the multimeter between the two pins.
              3) Check for continuity from DME 36 to main relay 85 and from DME 3 to fuel
              pump relay 85.
              I have this.
              Reconnect the coil, remount the CPS (air gap should be 0.040"), plug the
              relays back in, reconnect the DME, and connect the battery. Then do the
              following checks:
              I wasn't sure how I would measure pins if the DME was plugged in, so I didn't plug it in. I tested the pins on the harness inside the car.
              1) With the key off, verify that power is present at DME pin 18 and main relay
              86 & 30.
              I got 12.5v at pin 18.
              Power at the relay locations.
              2) With the key on, verify that power is present at DME pin 27 and pin
              18. Power to pin 18 is from the main relay and there should be power to the
              injectors and fuel pump relay.
              DME pins 18 & 27 both have 12.2V
              3) With the key on, verify that no voltage is present at the DME grounds (2,
              14, 19, 24).
              No power at any of these pins. Tested with both multi meter and test light.
              4) Verify that power is present at the coil positive and at fuel pump relay
              pin 30. Those get switched power from the ignition switch via C101.
              Yes, I get 12.2V at the positive coil.
              I'm a little miffed. I think that I should get more resistance with the CPS connected in step 2. I also think that I should be getting 12.5v in the places that I'm getting 12.2v. But I'm not really sure. Maybe @Jlevie himself could lend a hand.
              • ThatOneEuroE30
                • Dec 2013
                • 8626
                #67
                Yea you've done all I could think of at this point. My car started after all this shit. What about talking to a forum member with a shop and get their input.
                1991 318i 4dr slick top
                Mtech 2 turbo restoration
                • ST1G
                  • Oct 2012
                  • 6689
                  #68
                  Yeah seriously. Or someone who knows what they are doing. I'll reach out to Jlevie if he doesn't respond and if no one else knows anything.
                  • ThatOneEuroE30
                    • Dec 2013
                    • 8626
                    #69
                    Maybe Steve, levent or Jon I think is his name(forecedfirebird) they all help me.
                    • dnguyen1963
                      • Nov 2011
                      • 2649
                      #70
                      From your diagnosis, it seems that your CPS is not sending the crank signal to the DME preventing the car from starting. Your engine is turning over, but the CPS is not detecting it. Measure the distance between the CPS and the tooth wheel again and make sure that it is correct.
                      • solo318
                        • Jun 2012
                        • 183
                        #71
                        Did you check the physical condition of the trigger wheel. If the bolts are loose or missing it will not give a signal. Also make sure the bracket is properly mounted.
                        • ST1G
                          • Oct 2012
                          • 6689
                          #72
                          I'll check the distance again with a feeler gauge.
                          I'm not sure what you mean by 'trigger wheel'.
                          • dnguyen1963
                            • Nov 2011
                            • 2649
                            #73
                            He meant the tooth wheel where the CPS is getting its signal from.
                            • ThatOneEuroE30
                              • Dec 2013
                              • 8626
                              #74
                              The harmonic balancer
                              • HennaE30
                                • Apr 2014
                                • 1965
                                #75
                                Have you checked the harness for continuity
                                Originally posted by flyboyx
                                how about if i yank the anal beads out of your ass like i'm trying to pull start a chain saw?
                                Originally posted by Northern
                                beer is my new liver cleanse.
                                Henna - '84 Hennarot 325e
                                Lola - '89 Schwarz 325is - being saved
                                Christine - '88 Schwarz 325is - Spec E30 Racecar
                                '01 White F150 Lariat 4x4 Supercrew - Daily
                                Dad's '05 Interlagosblau M3
