Car cranking, but not starting(Now with spark!)
  • ST1G
    • Oct 2012
    • 6689
    #76
    Originally posted by dnguyen1963
    He meant the tooth wheel where the CPS is getting its signal from.
    I see. Well the wheel look like it's functioning how it should. My sensor is mounted just like this one, except it had a 10mm bolt holding it not a 5mm allen.
    The CPS I had in there was very dirty, I cleaned it and still had no luck with spark. I put in the one from the yard (from car with broken tbelt) and that's the one I did the above testes with. I'm very suspicious of the CPS. I should probably pony up and buy a new one.
    Originally posted by HennaE30
    Have you checked the harness for continuity
    See post 66
    • HennaE30
      • Apr 2014
      • 1965
      #77
      See post 66
      Ah my bad... Missed that one
      Originally posted by flyboyx
      how about if i yank the anal beads out of your ass like i'm trying to pull start a chain saw?
      Originally posted by Northern
      beer is my new liver cleanse.
      Henna - '84 Hennarot 325e
      Lola - '89 Schwarz 325is - being saved
      Christine - '88 Schwarz 325is - Spec E30 Racecar
      '01 White F150 Lariat 4x4 Supercrew - Daily
      Dad's '05 Interlagosblau M3
      • solo318
        • Jun 2012
        • 183
        #78
        Measure the voltage at the coil while you are cranking the engine. Then use your fluke to measure engine rpms while cranking.
        • ST1G
          • Oct 2012
          • 6689
          #79
          How do I measure the engine rpms with the multi meter?
          • ThatOneEuroE30
            • Dec 2013
            • 8626
            #80
            Yea how do you do that? I'd pony up and buy a new CPS so you can be 100% it's not that.
            1991 318i 4dr slick top
            Mtech 2 turbo restoration
            • EyExR
              • Jan 2011
              • 959
              #81
              I know you mentioned this started as an intermittent problem but I would check the fusible link as well. Is your ECU getting power?
              From what I've read it definitely points to either a bad ground, main relay, DME, CPS or bad harness.
              Good luck
              My 325iX DIY Threads:
              Front Wheel Bearing Replacement
              325iX Rear Subframe Bushings and MUCH more w/pics!
              325iX Steering Rack Replacement, Suspension, & Oil Pan job w/pics!
              • ST1G
                • Oct 2012
                • 6689
                #82
                Yeah, that's what I gotta do I think. I'm going to go talk to the parts guy at at Import Parts Specialist, he is a wizard when it comes to e30s and owns a few. I guess if it doesn't fix it I could return it too.
                Good luck
                Again, post 66 eliminates a bad ground, main relay, DME, harness. I also stated in post 56 and 41 that my DME worked in a friends car, and his didn't work in mine, thus eliminating the DME.
                • ThatOneEuroE30
                  • Dec 2013
                  • 8626
                  #83
                  Yea do that for sure
                  • ST1G
                    • Oct 2012
                    • 6689
                    #84
                    I snagged a new CPS tonight. It was $50 so I pulled the trigger. I plugged it in and checked pins 46 & 47 on the DME harness and now I have 50 more Ohms. So that's a good sign :D I'm going to get it all the way installed and gapped right and see what happens. I hope this is it.
                    • ThatOneEuroE30
                      • Dec 2013
                      • 8626
                      #85
                      Let's hope! Possible to have it started by the end of the night
                      • HennaE30
                        • Apr 2014
                        • 1965
                        #86
                        Good luck! Hoping for you that it works out.
                        • ST1G
                          • Oct 2012
                          • 6689
                          #87
                          Guess what guise. NO SPARK.
                          So, I put in the new CPS, got it in there, got her all situated. No spark.
                          Then I get to testing. I decide to put the multi meter on the coil positive (pin 15), and ground (body) and I'm getting 192Ω I get the same 192Ω when I put the meter between the negative terminal (pin 1) and ground (body) This was with the ignition on. This still doesn't make sense to me, since if the positive is grounded then the coil wouldn't get the signal to send spark.
                          After a few attempts to get the car to spark with nothing I checked the coil again and now I get a millisecond of continuity between pin 15 on the coil and ground and then it goes to infinite resistance (open). Same with the negative.
                          I then tried the coil from my running car. Same thing with the moment of continuity. No spark.
                          I don't even know any more.
                          • ThatOneEuroE30
                            • Dec 2013
                            • 8626
                            #88
                            This is getting fucking confusing. I'd be like
                            • ST1G
                              • Oct 2012
                              • 6689
                              #89
                              Seriously . That's how I feel. The only thing I've ever tried to do that's more complicated than this is mega squirt.
                              • ThatOneEuroE30
                                • Dec 2013
                                • 8626
                                #90
                                Just yank the pos and throw in a m50 do a budget swap.
