Late model cluster to early eta car
  • mcdougal
    • Nov 2014
    • 251
    Just put an s52 in my early model eta car. My car has a Motometer cluster in it right now and I have a late model Motometer cluster with the 7k tach. From what I've read it sounds like I can swap the late model cluster to my car and everything will work other than the fuel gauge, which I will need to reuse from my early cluster? Is this correct?
  • PimpinWalrus
    • Oct 2013
    • 170
    Pretty sure everything should work except for the tach and econometer. They need to be spliced into the harness from the c104 connector in the glovebox.
    '86 Delphin 335i turbo -
    '88 Schwarz 325i -
    '94 w124 e420 -
    Turbo m30b35 Build Thread
    • mcdougal
      • Nov 2014
      • 251
      The tach in my current cluster is working as it has been spliced into the c104. What I'm trying to understand is if I can swap a late model cluster into an early model car.
      • Gregs///M
        • Mar 2012
        • 2459
        Yup, that is exactly right. You will need to make sure there is a coding plug in the front right corner of the cluster. Should be PN ending in 468.
        Swap your fuel gauge and you're good to go.
        Owner - Bavarian Restoration
        BMW and European Electronics Repair and Restoration
        www.BavRest.com
        My Feedback Thread
        Our Facebook!
        Follow our Instagram!
        • mcdougal
          • Nov 2014
          • 251
          Awesome thanks!
          • AndrewBird
            The Mad Scientist
            • 11898
            As long as your car is an 87 or later, it will work fine. More info here:
            • mcdougal
              • Nov 2014
              • 251
              http://www.r3vlimited.com/board/show...hlight=cluster
              I have an 86
              • reelizmpro
                • 9558
                It will work...just swap the fuel gauge.
                88 M3 - LACHSSILBER
                89 M3 - ALPINEWEISS II
