Car won't start (details in thread) ... Any ideas?
  • E30JACK
    • Apr 2014
    • 24
    car is a 1991 325i with an m50 stroker swap.
    Drove to work in my e30, everything worked normal as usual. 6 hours later when I go to leave work, I wasn't getting fuel to the fuel rail. Determined the fuel pump was bad, trailered it home, and I just now fitted a working pump. I am now getting sufficient fuel. My battery drained all the way dead sitting in my dads shop when I brought it home fyi. Now that I replaced the pump , I put a jump box on the battery expecting it to start, and it still just cranks and cranks and cranks over. It is getting fuel to the rail, so what else could it be considering the information at hand? Thx in advance
  • E30JACK
    • Apr 2014
    • 24
    Bump
    • mikerob97
      • Jul 2010
      • 140
      1. How did you determine fuel pump was bad?
      2. How do you know you are getting fuel to the rail now?
      3. Have you checked for spark?
      Mike
      Cary, NC
      Current Rides
      1991 325iC - For Sale
      2006 M3 Cabriolet
      Past Rides
      2000 323i Touring - Daily Driver
      1994 325is (S50) - Fast Car
      1998 Z3 - Fun Car
      1986 325e (i engine conversion)
      1969 Mustang Mach 1
      • e30onBBSs
        • Dec 2014
        • 1347
        ^ check for spark. Could be an ignition problem too
        BMW tech
        Umass Amherst
        05 wrx sti
        • rcsoundn1
          • Nov 2012
          • 3361
          how does it sound when its cranking? Does it crank easy? Pop off the oil cap and crank it by hand to be sure the T-belt didnt snap
          • 101
            • Jul 2011
            • 764
            I'm the first one to admit I don't know squat about the M50 and how its ECU interfaces with the fuel pump - but as others have said, check for spark and cam rotation.
            The only other thing that pops into my mind would be the fusible link to the ECU, located in the trunk. Sometimes the use of a jump box or booster cables will kill it - thereby killing power to the ECU.
            101
            The E30 collection:
            1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
            1987 325is - Delphin / Black Sport (son #3's)
            1987 325i Convertible - Triple Black
            1989 325iX Coupe - Diamondschwarz / Black Comfort
            1990 325iX Coupe - Sterling Silver / Grey Sport
            1981 Fiat 124 Spider 2000 - Green / Tan
            1998 Volvo V70 GLT - White / Tan
            1998 Volvo S70 T5 manual - White / Taupe
            2001 Ford Windstar - Silver / Grey (parts hauler)
            2006 Lexus GX470 - White / Tan (tow rig)
            • E30JACK
              • Apr 2014
              • 24
              So i am now getting fuel with sufficient pressure. I have spark. I have compression. The m50tu uses a timing chain btw. Cranks over easy but will not fire.
              My ECU is very hot after trying to start the car. I am wondering if it is fried for whatever reason (I have jumped the car many times) ? I am hoping to test it with another ecu soon.
              • E30JACK
                • Apr 2014
                • 24
                Bump ^
                • Sea Aych
                  • Apr 2013
                  • 765
                  Is fuel getting injected or is it just getting to the rail?
                  Check your injector ground at the front of the head? (it's on the thermostat housing on my m50nv)
                  1988 Atlantisblau Euro/Japanese 325i Cabriolet
                  1989 Schwartz 325i - now M50 powered! - now very dead
                  1998 Toyota 4Runner Limited
                  My 17,000km Big NA National Parks trip!
                  • E30JACK
                    • Apr 2014
                    • 24
                    Tested the new ECU ... Car still won't start. Gets fuel , spark , compression , good ecu. What else could it be....any sensors or fuses or anything stupid that cause it to not start? Checked injector ground and it's fine...I'm at a complete loss here.
                    • E30JACK
                      • Apr 2014
                      • 24
                      Figured it iut
                      • arch4ngel
                        • Dec 2008
                        • 791
                        What was the fix?
                        Project
                        Feedback
                        • squidmaster
                          • Aug 2011
                          • 2666
                          how do you leave people hanging like that....
                          • TRAK WDW
                            • Aug 2014
                            • 157
                            Originally posted by E30JACK
                            Figured it iut
                            Bump... Would like to know the fix..
                            Harp
