Compression Test w-w/o throttle
  • NCTerp
    • May 2015
    • 40
    I have recently purchased a '91 325ix (211k miles). Trying to establish baseline engine health. Did comp test- I forgot to hold the throttle wide open as is suggested in the Bentley manual and the "101 Performance Projects..." Book.
    Other than that I tested as per page 30 of the "101 ..." Book. Specifically, loosen plugs with engine cold, then tighten lightly. Warm up car, wait 5-10 min. Remove DME relay, remove fuel pump fuse. Test compression.
    Results- 95 degree air temp, 400ft above sea level if it matters.
    1: 135
    2: 132
    3: 135
    4: 138
    5: 135
    6: 135
    What can be gleaned from these readings? And, how would it be different if I held the throttle open. And lastly, should I do it over with WOT, and then add a tablespoon of oil and repeat?
  • ak-
    • 12422
    They're all within a tiny percentage of one another so I'd assume you've got a healthy motor and not worry.
    1991 325iS turbo
      • 34844
      they might be a little higher with the throttle open since more air would get in, but more importantly as AK said they're all pretty close relative to one another.
      • TobyB
        • 5296
        Thirded- we have a big enough plenum AND the IAC stays open when cranking-
        you have a decent motor.
        t
        • barbierij
          • Sep 2012
          • 1294
          Throttle open is a necessity. You want as much air as possible to enter the cylinders. A closed throttle could give wrong results because a closed throttle 'could' act as a closed valve. A vacuum test at idle and a cylinder leak-down test will help you determine the engine's health. Did you do a compression test cold, warm, and then test with a bit of oil in the cylinders?
          Sent from SPACE using Tapatalk 2
          FS NY: two Audiobahn A235HC amps and audiobahn 1farad capacitor
          Saab/GM tech2 programming
          My for sale thread
          1990 325iX for sale or part out
          Did you buy something from me? Please leave feedback!
          Originally posted by K20RI_211
          And I have to ask if you make a hobby out of thread-bombing with retarded questions?
          • TobyB
            • 5296
            I've routinely forgotten to open the throttle, even on the 2002 with sidedrafts, and the
            biggest difference I notice is that it takes a few more cranks to build to about the same number....
            t
            • NCTerp
              • May 2015
              • 40
              I only tested warm.
              • TobyB
                • 5296
                You are good to go, at least as far as the mechanicals of the engine...
                t
