Importance of OEM nuts/bolts
  • ElJimo
    • Jun 2012
    • 166
    http://www.realoem.com/bmw/enUS/show...diagId=31_0041
    I'm currently replacing my front suspension components. When replacing parts such as #10-13 can I just go to a general hardware store and pick those up? There's nothing special about the BMW parts other than their cost, right?
    Part numbers for reference:
    07119902955
    31111114348
  • TravisAsch
    • Jul 2015
    • 34
    I say go for the hardware store and use grade 8's
    • ElJimo
      • Jun 2012
      • 166
      Alright, thanks. will do.
      • ThatOneEuroE30
        • Dec 2013
        • 8626
        What Travis said. Hardware store bolts and nuts are fine as long as they are grade 8 or higher any thing under grade 8 isn't meant to carry the load a car would put on them.
        1991 318i 4dr slick top
        Mtech 2 turbo restoration
        • rturbo 930
          • Dec 2005
          • 2625
          I think as long as you match the grade of the bolt (usually grade 8, but sometimes higher, so you should check what it was) you should be fine.
          • Boris3
            • Apr 2007
            • 444
            Be careful about metric equivalents with hardware store bolts and nuts. Grade 5 SAE is metric grade 8.8. Grade 8 SAE is metric grade 10.9.
            1990 325: track/racecar
            2003 330xi; project car
            2004 330i zhp: civilized car
            • jalopi
              • 2370
              if you can, try to get metric replacements. while they'll work, the standard bolts will be ever so slightly smaller in diameter than their metric equivalents.
              for a bolt like #10, that could leave you with some slop in the swaybar endlink. probably not enough to effect handling... but you never know. just saiyan
              • jrobie79
                • Mar 2006
                • 2526
                my local ace hardware has all kinds of metric bolts grade 10.9
                1991 318i ---- 308K - retired
                  • 34844
                  the factory bolts are zinc coated. Cheaper bolts will be plain or maybe nickel coated, which is prone to rust. Ace does sell some nicer bolts that have a good coating on them, but they're not really any cheaper than buying them through BMW a lot of times.
                  personally, I began hoarding stock fasteners a long time ago every time I parted something out or took something apart. I clean them and store them in sorted bins. As long as they aren't damaged or rusty, the original fasteners are probably better than what you can get at a hardware store. And I have basically everything so if I lose something or need to replace one for some reason, I've probably got 10 more just like it.
                  • jalopi
                    • 2370
                    OP you probably have a Fastenall in your area - all they sell is every variation of nuts and bolts you can think of
                    go there and you'll be good to go
                    • ElJimo
                      • Jun 2012
                      • 166
                      Boris3 -Thank you for that clarification, I know vary little about hardware grade specifications, so that definitely saved me a future headache.
                      Nando- Thanks for bringing up the coating issue, that's something I was worrying about. The reason why i need new hardware in the first place is when I was trying to remove the swaybar endlink mounts, the bolts sheared right off from corrosion.
                      Jalopi- Thanks for the heads up. I'm gonna check out ACE first because it's literally across the street from my house, but if they don't have it I was going to check out fastenal/mcmastercarr
                      • 101
                        • Jul 2011
                        • 764
                        I agree with Nando.
                        I've found that the BMW bolts are not all that expensive, and the coating (along with application of anti-seize) will make it way easier on the next guy.
                        101
                        The E30 collection:
                        1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
                        1987 325is - Delphin / Black Sport (son #3's)
                        1987 325i Convertible - Triple Black
                        1989 325iX Coupe - Diamondschwarz / Black Comfort
                        1990 325iX Coupe - Sterling Silver / Grey Sport
                        1981 Fiat 124 Spider 2000 - Green / Tan
                        1998 Volvo V70 GLT - White / Tan
                        1998 Volvo S70 T5 manual - White / Taupe
                        2001 Ford Windstar - Silver / Grey (parts hauler)
                        2006 Lexus GX470 - White / Tan (tow rig)
                        • jeffnhiscars
                          • Jun 2011
                          • 6011
                          I love my nuts n bolts hoard
                          Fastenall def has a great selection but if they have to,order in anything less than a box, they will charge you a pick fee which you won't like.
                          Alice the Time Capsule
                          • jalopi
                            • 2370
                            BMW bolts aren't expensive when you look at the price for one individual bolt
                            but they're quite expensive when you consider a 50 pack would cost $31 from BMW whereas mcmaster/fastenal would only charge you $13. or you could spend the same amount of money and upgrade to stainless
                            yeah i know it isn't the best example since you'd never need that many m8x45's on your car, but the car still has a shitload of bolts if you'd ever need to replace em
                            all the stores in my area started doing this about a year or two ago too. people weren't too pleased so they started selling these little baggies that had 2-4 nuts or bolts in em. which was nice to offset the pick fee, but their prices literally doubled. ever since then i only go to fastenal if i need something ASAP. otherwise i order from mcmaster
                            • george graves
                              • 20003
                              Yep - as other said - part out another e30 and save ever single nut and bolt you can. It's a total life saver.
                              I just don't trust hardware store stuff.
                              Originally posted by Matt-B
