Smoking from under the hood?
  • Underpowered
    • Jun 2006
    • 23
    A coolant hose popped on me two days ago (nevermind how), and it took part of the radiator with it. Not a big part, just a piece of the inlet. I reattached it and refilled the car with coolant and have been taking it easy, but theres still smoke coming from under the hood! Its coming from the back of the engine bay, and it looks like its coming off of the exhaust pipes. Could this still be coolant evaporating?? its been two days!
  • Sean
    • 5793
    Yes, it's coolant burning off - it'll subside eventually. lol
    How much have you driven in two days? Just a couple miles?
    - Sean Hayes
    • Brew
      • 3060
      Headgasket
      '91 318is
      • Sean
        • 5793
        Originally posted by Brew
        Headgasket
        If it was his headgasket, wouldn't he be overheating?
        - Sean Hayes
        • BahnE30
          • 1050
          check the coolant hose you replaced, not the hose it self but where it's attached to the rad and the block or whatever, make sure the car is up to temp so the coolant is flowing and under pressure, it could still be leaking, but if you've driven for more than 30 minutes the coolant should all be burned up. that is unless it's still leaking....
          • Garageaholic
            Freestyle Fabricator
            • Dec 2005
            • 5204
            If it took a piece of the inlet when the hose burst, maybe it's leaking from there and making its way to a hot part of the engine where it can evaporate... new radiator....
            Recent Rebranding!!
            E30 SM62/S62
            E30 M60 V8
            E30 M30 Big 6!
            Instagram.com/garageaholic
            Youtube.com/garageaholic
            • moatilliatta
              • 6158
              The hose poped cuz it overheated cuz of headgasket. WCS
              @Zakspeed_US
              • sticksdaman
                • Apr 2005
                • 2987
                let the car sit and idle for about 20 minutes if its still smoking then its not the collant burning off of the exhaust manifold..its probably the headgasket as stated
                Originally posted by ebelements
                Also, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
