Mystery Noise: Differential or Wheel Bearings?
  • allen_t
    • Feb 2014
    • 552
    Having similar issue with mine but only under 2k rpm. See vid
    http://www.DeluxeCarStorage.com
    87 325ic - Early ACS Tribute
    90 325i MT2 - R.I.P
    Seller Feedback: http://www.r3vlimited.com/board/showthread.php?t=380908
    • loganhopeless
      • Mar 2015
      • 78
      I had the exact same problem, it ended up being shot inner pinion bearings.
      • dvallis
        • Oct 2015
        • 1474
        Thanks for the info. I'm definitely going with bad diff as the root cause. Did you buy a new diff or pay for a rebuild?
        "And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
        1987 E30 3L Turbo Stroker Das Beast
        2002 E39 M5
        • HennaE30
          • Apr 2014
          • 1965
          The rebuild for the race car wasn't cheap (came out to about a grand iirc) but it's all new now.
          Originally posted by flyboyx
          how about if i yank the anal beads out of your ass like i'm trying to pull start a chain saw?
          Originally posted by Northern
          beer is my new liver cleanse.
          Henna - '84 Hennarot 325e
          Lola - '89 Schwarz 325is - being saved
          Christine - '88 Schwarz 325is - Spec E30 Racecar
          '01 White F150 Lariat 4x4 Supercrew - Daily
          Dad's '05 Interlagosblau M3
          • Northern
            I like cupcakes & sh!tboxes
            • 5265
            Just mentioning this because I don't think it has been yet, but fuel pump?
            In tank or external.
            Originally posted by priapism
            Originally posted by shameson
            • Exodus_2pt0
              • 5943
              This is a time where it would be worth it to pay for an hour of shop diag.
              Best way to diag this is to put it on a lift with someone In the drivers seat, then run the car up to 70-80 mph and walk around underneath with a stethoscope until you find the culprit.
              You could do it on jack stands, but I wouldn't be crawling underneath it.
              That said, this sounds like a differential issue to me.
              No E30 Club
              • jeffnhiscars
                • Jun 2011
                • 6011
                That would not be speed dependent.
                Alice the Time Capsule
                • AwakenNoMore
                  • Dec 2010
                  • 1291
                  Mine also makes this same exact noise, I'm pretty certain it's the pinion bearings. Which is a bummer because it's supposedly a rebuilt unit with an extra clutch.
                  1991 325i - "Scambles" The Daily Driven lightly modded.
                  1988 Mazda RX-7 TII "Mako" The Free Dorito
                  bacon by Jared Laabs, on Flickr
                  • chadthestampede
                    • Jul 2008
                    • 3601
                    Fwiw, my car was making a very similar noise. Swapped the diff and it's whisper quiet now.
                    Originally posted by LJ851
                    Feedback
