Mystery Noise: Differential or Wheel Bearings?
  • dvallis
    • Oct 2015
    • 1474
    So, after removing the rear seats from my E30 I can hear a very loud whine from the rear of the car. It sounds like this at 70 mph. Here's a frequency spectra of that same noise.
    Looks like the offending sound is about 6.5 KHz. Filtering out all the road noise etc. and you are left with this.
    Things I have determined:
    1. Noise does not change when I press or lift the gas, no matter what gear
    2. Noise does not change if I turn the steering wheel
    3. Noise does not change if I step on the brakes
    4. Seems to be 100% speed dependent. Higher the speed, louder and higher frequency the whine
    5. Changed my LSD diff fluid with 75-W140 Valvoline synthetic. No change
    Anyone out there with ideas?
    Thanks
    "And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
    1987 E30 3L Turbo Stroker Das Beast
    2002 E39 M5
  • HennaE30
    • Apr 2014
    • 1965
    So it is speed dependent only?
    Where in the back does it sound like it's from? One of the sides or in the middle? Also what kind of bushing did you use when you put the diff back in, anything stiffer than OEM rubber and you'll notice progressively more whine the stiffer you go.
    Also check that you tightened all the bolts down, unlikely that it's that, but you never know.
    Originally posted by flyboyx
    how about if i yank the anal beads out of your ass like i'm trying to pull start a chain saw?
    Originally posted by Northern
    beer is my new liver cleanse.
    Henna - '84 Hennarot 325e
    Lola - '89 Schwarz 325is - being saved
    Christine - '88 Schwarz 325is - Spec E30 Racecar
    '01 White F150 Lariat 4x4 Supercrew - Daily
    Dad's '05 Interlagosblau M3
    • dvallis
      • Oct 2015
      • 1474
      It's definitely speed dependent only. The sound seems to be coming from dead center behind the rear seat. Maybe a bit to the driver's side. And it's a freaking loud 6K high pitched whine at 70 MPH.
      I changed the fluid with the diff in place. Didn't touch any of the mountings.
      So weird.
      2002 E39 M5
      • redlightpete
        • Mar 2012
        • 266
        Diffs are loud, hence the super heavy 'trunk tar'. Once the pinion bearings wear out they are really loud.
        • pandaboo911
          • 2070
          I have no trunk tar, no rear seat, solid differential mount and an LSD with 260k miles and it doesn't make the slightest noise.
          • TobyB
            • 5297
            That seems to rule out the diff gears, at least- a noisy ring and pinion will change tone
            (spectral content, usually, not frequency) when you lift.
            It makes sense- if the drive side of the gears are chewed up, when you lift,
            you're now loading the coast side of the gears, and if you match revs
            perfectly, there should be no load on them at all.
            If it's a wheel bearing, it usually changes when you corner reasonably hard.
            (mp3 sounds like you have a table saw in the trunk. Which IS consistent with diff...
            maybe the side case bearings? The pinion bearings SHOULD change tone with loading.
            Was the thing ever 'rebuilt'?)
            t
            all I got,
            • bmwstudent
              • Sep 2011
              • 1364
              more charts and graphs I can't understand please
              • chadthestampede
                • Jul 2008
                • 3601
                Mine makes almost this exact same noise. I just assumed it was the diff.
                Originally posted by LJ851
                Feedback
                • dvallis
                  • Oct 2015
                  • 1474
                  It freaking does sound like a "Table saw in the trunk"! ;-)
                  No clue if it was ever rebuilt. I've owned several track cars and the diff never sounded like this.
                  2002 E39 M5
                  • jake5
                    • Sep 2014
                    • 83
                    Have you guys checked the inline bearing on the driveline?
                    Sent from my LG-H631 using Tapatalk
                    • varg
                      Florida Turbo Man
                      • May 2014
                      • 3431
                      It's not the wheel bearings, bad wheel bearings make it sound like you're in the cheap seats on an airliner. My diff whines audibly through my solid condor rear end bushings, and it sounds like the noise you hear in a subway/metro when it's accelerating.
                      IG @turbovarg
                      '91 318is, M20 turbo
                      • dvallis
                        • Oct 2015
                        • 1474
                        Where is the driveshaft bearing in relation to inside the car. I don't have a lift in my garage so it's hard to see under there.
                        2002 E39 M5
                        • Seawolf
                          • Feb 2015
                          • 270
                          If that's a pic of your driveshaft, it doesn't look right at all.
                          That drive shaft must be centered in the tunnel, one bolt isn't fully home and it looks like the bearing might be in contact with the body on one side - that will make a hell of a racket inside the car if it is.
                          • dvallis
                            • Oct 2015
                            • 1474
                            That's not my driveshaft. Just a picture I found online. Where are the tunnel bracket bolts with respect to the inside of the car?
                            2002 E39 M5
                            • Todd Black 88
                              • Oct 2007
                              • 3449
                              I have the same noise.
                              100% speed dependent. I hear it at around 15 mph and up, and gets louder with speed but not with throttle on/off. Clutch in at any speed and it still makes it.
                              I assume it's my diff because everything else is new or rebuilt, from the engine back.
                              Originally posted by codyep3
                              I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
                              2001 silver/Blk 325 cabby. SOLD
                              2002 325xit Sil/blk. SOLD
                              2010 F650gs twin
